Cabin ceiling cover/fabric falling apart
Old Jun 7, 2018 | 07:00 PM
BlazingSaddle's Avatar
Default Cabin ceiling cover/fabric falling apart
I'm not exactly sure what to call it but the back of the ceiling fabric came off and it hanging down like a cow's tongue. I recall reading about replacing the whole thing but has anyone experienced something like this? Any thoughts on what kind of glue would be best for fixing this minor issue? See below for a photo of it. Thanks a lot folks.
Old Jun 7, 2018 | 08:50 PM
Steve Jr's Avatar
Default Re: Cabin ceiling cover/fabric falling apart
If you'll notice there's a fine layer of the backing left on the headliner. Its like glueing something to sand. To light of an adhesive an it will keep coming down. To heavy an it will bleed thru the fabric...
Old Jun 7, 2018 | 09:20 PM
SteveS's Avatar
the "glue" holding the fabric and the backing in place is done for ... you need to go to an upholstery shop to get it all fixed.
Old Jun 7, 2018 | 10:39 PM
It is the foam that has deteriorated. Trust me, the glue is still on the headliner and strong as ever. When you go back with new material, use material that does not have a foam backing.
Old Jun 8, 2018 | 07:52 AM
I had exactly the same area fail so I rubbed the foam of the fabric liner and the panel with my fingers, applied some double sided tape along the panel and then stuck the fabric to the tape. I used an industrial tape but I am sure that a good tape would do the trick. A simple solution until I get around to doing the proper job.
EDIT
The double sided tape failed in the heat, thumb tacks work on the vertical surface and as the whole thing is now falling self tapping screws work well on the horizontal face.
Old Jun 8, 2018 | 11:10 AM
Thanks a lot for the responses. Ok, so it is called a headliner.... how did I miss that? :-)
So, the consensus is that no one has succeeded gluing it back on because of the deteriorated foam on the fabric. 180's temp solution definitely is temporary... I thought about using a clear sealant used for roof repair. It goes on like a gel so it will have the bulk (unlike a glue spray) and it has the power to hold things but I just don't know what it will be like longer term. For those of you who have resorted to an upholsterer, did he/she replace the headliner or reused it?
Old Jun 8, 2018 | 11:35 AM
They always use a new material, the old material has rotted foam stuck to it and has been stretched beyond the point of reuse.
The new material is pretty cheap to buy.
Old Jun 8, 2018 | 11:51 AM
Some of the high end guys actually used suede leather.
I have a roadster so God does my headliner
Old Jun 8, 2018 | 04:43 PM
The upholstery shop I use locally does excellent work and re-covered my headliner with a material & color that closely matched the OEM material. Wife & I pulled the headliner out ourselves (lots of great DIY advice on how to do that step) and cost me $130 to have the headliner cleaned/stripped of all old glue residue and the new material applied. Shop made sure that the new material "wrapped" around the mating edges of the headliner to help hold it in place and keep it secure when installed. OEM headliner barely covers the headliner board to the edges and that also contributes to a sagging headliner besides a poor glue job.
I also took Waldig's advice and applied some sound deadening material to the bare roof before we installed the new headliner. Remarkable difference in cockpit noise. Here's a link to his video post about this. CLICK
Old Jun 8, 2018 | 05:53 PM
I am going to have to do my roof liner pretty soon and I was wondering about that sound deadening. My wife says the car is too noisy, I just turn of my hearing aids, this has two benefits, I do not notice the car noise or my wife's complaints. A win win situation.
I currently have all the trunk panels out and the noise is noticeably louder, maybe I can do something back there as well.
Old Jun 8, 2018 | 10:00 PM
waldig's Avatar
Talking Re: Cabin ceiling cover/fabric falling apart
Sound liner really does help. I also covered liner shell with polyurethane to form a stronger and smoother base for the new liner. I also went with dark to reduce back light during the day, less ''glare'' effect. Enjoy Woody
Old Jun 11, 2018 | 11:56 AM
Here's a link to a more detailed photo instruction on how Waldig replaced his headliner.
What I haven't seen yet is how he got the entire headliner unit off the ceiling. Anyone know how? Just pull hard? Anything that might break?
https://www.crossfireforum.org/g/album/5832983
Old Jun 11, 2018 | 11:58 AM
Sorry, Waldig... didn't realize you had just posted .... so, how did you remove the whole thing?
Old Jun 11, 2018 | 09:17 PM
hercrossfire's Avatar
i completely replaced the whole headliner, same color and it looks so great
. I had it done in Wisconsin. I had to pin it back up before i found the gentleman that did it. so very happy
Old Jun 12, 2018 | 11:59 AM
Grey Ghost did a nice write up on how to remove the whole headliner.
I’ll add the link here. CLICK
Old Jun 13, 2018 | 08:12 AM
Wife & I removed the headliner when I had it recovered last year. GraphiteGhost's write-up was excellent in providing more detail than the Service Manual. The only thing we did different than his write-up was we only pulled the rear trim panels down from the top and left them hanging from the bottom pins. (Note: That is per the Service Manual.) That provided enough of a gap where I could see the 2 pins holding the headliner rear to the roof and using a trim removal tool, pulled those pins out. We were able to slide the headliner out of those trims panels when we worked it down, forward & out of the PS door opening. And like his write-up, going back was a piece of cake! We only had to replace a damaged pin in one of the rear interior trim panels.
And I would add that removing the A-pillar trim panels requires some significant force. Those are really stuck to the structure. Almost scary how hard I had to pull to get them loose.
killerkanadian
Sep 25, 2011 04:35 PM
JasonSmith
Aug 3, 2008 01:46 PM
MAKIII
Jan 27, 2008 08:36 PM
Romio
Feb 23, 2007 11:42 AM
dwolfenb
Aug 12, 2005 10:42 AM
