RCM again?
Old Aug 23, 2018 | 12:40 PM
Robertwav1's Avatar
Default RCM again?
Just for your information. Some 10 years ago or so the solder connections went bad on the RCM. Well, fixed them at that time and just out of nowhere the car quit, wouldn't start, waited a while and got the car home. My first thought was the RCM again but how could it be that, I've already addressed it years ago? Well it was, joints were poor again under a glass. Guess I should have done the Mod at the time but figured, no big deal, the re-solder should be fine. Mind you, it's been 10 years ago and it held up fine to this point. I'm one of those that keeps vehicles forever. Anyway, redid them again and problem solved once again. I guess it's a hot spot on this board and that's why the mod should be done to eliminate this problem. Thought I'd reach out and let people know in case they already fixed this and it came back.....it did take a long time though.
Old Aug 23, 2018 | 06:39 PM
Default Re: RCM again?
I can see no reason for a good solder job to fail, the terminals must be cleaned prior to resoldering and sufficient heat applied to avoid a cold joint. The use of acid flux or acid cored solder will cause future failures as well, only use resin cored solder for electronics.
Some say vibration is the culprit and that is not true.
Poor soldering caused the failure on the original RCMs.
Burnt contacts are the cause of many relays to fail, if they get burnt replace the relay ASAP.
Old Aug 27, 2018 | 11:38 AM
Robertwav1's Avatar
Thanks, I did have to replace with a new one. Even though the solder joints were looking a little funky it wasn't the problem. The center relay was a little discolored but kinda hard to look at the contacts unless removed from board. I checked diode and resistors and went over the entire board solder wise and it didn't help, shut down within a minute or so. For $132.00 on amazon, brand new and the joints all look good. Very dangerous situation when it shuts down (My wifes car) can't have that happen. Thanks for input though!
tighed1
Jan 11, 2025 05:45 PM
waldig
Sep 28, 2012 02:16 PM
NYPD-Crossfire
Oct 21, 2009 02:21 PM
chelseaccox85
Dec 18, 2008 01:16 PM
Bleu Chocolate
Apr 5, 2008 03:36 PM
