Remote starter switch
Old Sep 7, 2021 | 06:05 PM
zippo's Avatar
Default Remote starter switch
Hi All,
I am, almost, the happy owner of a 2004 Crossfire. Picking it up later today. It does not start. Current owner says it is probably a rely problem. Loading it on my trailer will be easier if it is running.
Is there enough room in the engine bay to reach the starter and attach wires of a remote starter switch to the “power” and “start” terminals of the starter? I’ve never been closer than 10 feet to a Crossfire, so I know virtually nothing about these cars. I did read about repairing/replacing the RCM. I can do that once the car is in my driveway.
Thanks for any and all input.
Old Sep 7, 2021 | 06:20 PM
Default Re: Remote starter switch
Does it have keys? What does it do when you try to start it?
Old Sep 7, 2021 | 06:22 PM
To answer your question though, no you can not bypass the security system to start it. They are quite theft proof.
Old Sep 7, 2021 | 06:31 PM
zippo's Avatar
The car has keys. I have not seen the car in person, so I do not know what, exactly, the no-start condition is. I am going by the owners statement that it is probably a relay issue.
I was thinking I could turn the ignition to "run" and if necessary to "start" and press the remote start switch to engage the starter. Either it would start or not.
Is there enough room to access the wires attached to the starter solenoid?
Old Sep 8, 2021 | 01:37 AM
zippo's Avatar
Thank you for the assist. The car is now home. Never attempted to use the remote starter switch; the car's battery was dead.
Old Sep 9, 2021 | 04:35 PM
Can't wait for any follow-up! Good luck, and welcome to the forum and perma-grin club!
Old Sep 9, 2021 | 08:04 PM
There is no switch, you would have to wire it in. They worked in the old days on the relay that was on the inside of the fender. Most just used a screwdriver instead.
Old Sep 10, 2021 | 02:16 AM
zippo's Avatar
A thumbs-up to all that contribute to the Crossfire Forum. This site provides a wealth of information. Information that helped to locate the source of, and repair of, the car’s no-start condition. In short order I found the RCM solenoid pack, cleaned a corroded connector and re-soldered two PCB connections. The car is now running. Yet, the location of the starter is still unknown to me. I’ll be OK if I never need to learn its location.
Thanks for the assist.
Old Jan 12, 2022 | 03:39 PM
M SL 65's Avatar
Oh for the good old days, when a connection to the positive terminal and the starter relay would crank a motor over. Great for checking compression etc.
With twelve coils per car, out of this world ignition security etc., has anyone figured out how one person standing outside the XF, can crank the engine over.
Old Jan 12, 2022 | 07:15 PM
With twelve coils per car, out of this world ignition security etc., has anyone figured out how one person standing the XF, can crank the engine over.
You can do it that way, but if you don't wanna crawl under the car, this is how I do it (I've only done it twice in 12 years):
fff
Make damn sure the car is in Park or neutral - this bypasses EVERYTHING and engages the starter - PERIOD.
rrr
1) Remove cover over underhood fuse box.
2) Pop the fuse carrier out of the box and lift it up and away 2-3 inches.
3) Yank the Pulse module out and unplug it.
4) Pop the cover off the Pulse Module.
5) Plug the module back in and press on the starter relay. (If the key is "ON", the engine may start, certainly the plugs and fuel injectors should fire. If the key is "OFF", the plugs and fuel injectors won't fire, but the starter WILL engage.)
6) There are two relays, if nothing happens, try the other relay (second relay is for the coolant pump in SRTs, even Limiteds and Base models have both relays.)
Old Jan 13, 2022 | 12:26 AM
zippo's Avatar
We’ve resurfaced! The solder joints have held. Car’s on the road. I still have yet to find the starter, nor have I looked for it. After the car’s long hibernation there were a few glitches to iron out. Those glitches are done and gone. This is a fantastic automobile. What a hoot to drive. My little liebchen.
tpwalbert
Mar 7, 2021 09:41 AM
tomtom540
Apr 21, 2020 10:57 PM
Brian P
Jan 27, 2020 10:34 AM
Pinopolis
Feb 4, 2015 10:11 PM
jto4
May 17, 2011 10:07 PM
