Alarm not working
Old Jun 23, 2022 | 08:00 PM
Chryscross1's Avatar
Default Re: Alarm not working
Thanks everyone-- appreciate it.
Old Apr 14, 2023 | 10:53 AM
bluecoupe's Avatar
I just noticed this morning when I locked the doors on my SRT6 that I didn't hear the chirping sound from the alarm that I usually do. I had replaced the original siren for the same reason with the new updated version in May 2016. I checked the fuse it was OK, dome light and trunk light still worked. I tried the panic button on both fobs, one was a new, never used fob, and then did the lock the doors with the window open and then open the door with the inside door release test, still no alarm. I guess batteries are pooched again I was hoping to get 10 years out of it, but no luck. I'm going to remove the siren, split the case and check to see if the condition of the board, if it's not corroded, I'll change out the batteries. I got lucky doing this previously with the siren on my Limited. If the siren can't be repaired, then I'll go without, I still have the piezo buzzer I put in years ago and it still works when locking/unlocking the doors.
Old Apr 14, 2023 | 12:53 PM
bluecoupe's Avatar
So I have an update. I removed the siren from the SRT, it's the new style that chirps when you lock & unlock the doors. Unfortunately it doesn't have a seam I can cut along to separate into 2 halves like the old style does, so I'm not sure how to open it without damaging it. When I separated the electrical plug from the siren, the siren went off as I was holding it in my hand and the lights flashed. The siren stopped after 2 or 3 seconds but the lights kept flashing until I pressed the unlock button on the fob. I reconnected the siren electrical connection and laid the siren on the cowl frame with the metal siren mount against the cowell and pushed the panic button on the fob but no sound from the siren. I then locked the doors with the fob and heard the siren chirp and saw the lights flash. I then reached through the driver window and opened the door using the inside handle and the siren went off, lights flashed. I pressed the unlock button on the fob, the siren went off and chirped and the lights flashed. I pressed the panic button, but the siren didn't go off. I locked the doors with the fob, I heard the siren chirp, the lights flashed and I then opened the door using the inside handle, this time the siren didn't go off. I disconnected the siren again and it went off for a few seconds, the lights flashed, I pressed the unlock button on the fob and the lights stopped flashing. I repeated this a few times but couldn't get the siren to go off again when opening the door. It only now goes off when I pull the electrical connector. The good news is the chirp is back when locking/unlocking with the key fob. The bad news is I can't get the siren to work again. I'd appreciate your thoughts and suggestions. Has anyone separated the new style alarm successfully to replace the batteries?
Old Apr 15, 2023 | 09:55 AM
[QUOTE=bluecoupe;978418]So I have an update. I removed the siren from the SRT, it's the new style that chirps when you lock & unlock the doors. Unfortunately it doesn't have a seam I can cut along to separate into 2 halves like the old style does, so I'm not sure how to open it without damaging it. When I separated the electrical plug from the siren, the siren went off as I was holding it in my hand and the lights flashed. The siren stopped after 2 or 3 seconds but the lights kept flashing until I pressed the unlock button on the fob. I reconnected the siren electrical connection and laid the siren on the cowl frame with the metal siren mount against the cowell and pushed the panic button on the fob but no sound from the siren. I then locked the doors with the fob and heard the siren chirp and saw the lights flash. I then reached through the driver window and opened the door using the inside handle and the siren went off, lights flashed. I pressed the unlock button on the fob, the siren went off and chirped and the lights flashed. I pressed the panic button, but the siren didn't go off. I locked the doors with the fob, I heard the siren chirp, the lights flashed and I then opened the door using the inside handle, this time the siren didn't go off. I disconnected the siren again and it went off for a few seconds, the lights flashed, I pressed the unlock button on the fob and the lights stopped flashing. I repeated this a few times but couldn't get the siren to go off again when opening the door. It only now goes off when I pull the electrical connector. The good news is the chirp is back when locking/unlocking with the key fob. The bad news is I can't get the siren to work again. I'd appreciate your thoughts and suggestions. Has anyone separated the new style alarm successfully to replace the batteries?[/QUOT
It MIGHT be that the little 'pin' that hits the panic button switch inside the remote has broken off inside the FOB. Thats about the only thing I can suggest. Good luck!
Old Apr 15, 2023 | 11:43 AM
bluecoupe's Avatar
[QUOTE=GraphiteGhost;978450]
Thanks, I thought it might be the remote button too so I dug out my new never used fob, put some fresh batteries in it and gave it a try but no luck so I went to the MB store and ordered a new siren, ouch $230 CDN with taxes all in. The date on this siren which I installed in May 2016 is 15-8-15, so about 9 months old. I had hoped they would last more than 8 yrs and I said so to the Parts fellow. We agreed that the new siren should have a manufacture date from this year or he'll return it and get me a fresh one.
Old Apr 22, 2023 | 01:04 AM
nickwe21's Avatar
[QUOTE=bluecoupe;978453]
Why not order the siren module online and save yourself a heck of a lot of money? I want to say I paid under $100 for the updated one. The one with the beep.
I steer clear of dealerships of any kind as they usually have a 300 percent markup.
Old Jun 17, 2023 | 07:29 PM
AZPatriots's Avatar
Hello,
On that topic of the newest/updated alarm siren - I see Mercedes Part #A 219 820 32 26 based on previous postings related to this topic. Is this in fact that most updated siren available or should I be looking for a different part number. If so, can someone provide such.
As a note, I realize that the newer sirens have studs requiring a metric washer and nut.
Thank you in advance!
Old Jun 17, 2023 | 08:50 PM
Originally Posted by AZPatriots
Hello,
There is another beeping siren which uses the screw as per our cars. I did a pdf on them both and you can find it noted in my sig line in red. Just open it and you will find it in electrical I think.
Old Jun 17, 2023 | 09:02 PM
AZPatriots's Avatar
Hello,
Thank you and yes, I already downloaded that PDF file. The second part number matching what you describe just appears to be a lot harder to find. I just want to make certain that the first part number is the most up to date siren. I have found a couple of outlets that appear to have it for around 140-160 U.S. dollars.
Thank you for the follow up response - much appreciated.
Old Jun 21, 2023 | 11:25 PM
Joliet John's Avatar
I just replace my alarm module with the updated Mercedes part from Needswings. I notice the car now automatically locks about a minute or two after I turn it off. Anyone know if I can turn this feature off, and if so, how?
Old Oct 25, 2024 | 07:38 AM
robdoy's Avatar
[QUOTE=nickwe21;978672]
Hello, just wondering where you purchased the siren online. thanks
Old Oct 25, 2024 | 04:57 PM
DTMenace's Avatar
[quote=robdoy;993784]
robdoy
Click on the 1st link below to obtain the siren you're looking for at this time. A longtime supplier to the Forum members.
The second link is the how to Youtube vid....
Dennis
DTMenace
NeedsWings Performance Products. Updated OEM Alarm Siren
Old Oct 29, 2024 | 10:35 AM
Mad Dog's Avatar
Hello,
I'm 2 weeks new to the CF community and pleased to have my new 2005 Limited running again after Josh at MERCEDESSWAPSHOP repaired my SKREEM. Yesterday though I was dismayed when again my CF was experiencing the dreaded two 1 second starts. Thinking maybe my SKREEM had failed, I contacted Josh. He quickly replied and instructed me to disconnect the ALARM (which hadn't been working anyway!). Sure enough, my CF started and ran normally. I'm wondering if it's even needed or worth replacing the alarm. Any thoughts? BTW Huge kudos to Josh at MERCEDESSWAPSHOP - again!
Old Oct 29, 2024 | 10:52 AM
If you park it outside, maybe, however in my opinion no one pays attention anyway.
Old Oct 29, 2024 | 09:22 PM
Originally Posted by Mad Dog
Hello,
You can live with out the alarm. Just tape up the connector so it doesn't short out.
I replaced mine with a new one. If you would like a detailed description of how to replace the alarm, click the link:
Alarm and drain cleaning
Old Nov 3, 2024 | 09:56 AM
Mad Dog's Avatar
Hi,
Thanks for the response. I'm going to leave it off for now - it hadn't worked since I got the CF anyway. Mike
cdlrodgersrns
Jul 30, 2021 08:47 AM
Vintage Fire
May 16, 2016 08:46 PM
JayDTats
Apr 28, 2015 01:55 PM
typhoon55
Jun 3, 2011 04:45 PM
simmie777
Feb 17, 2011 06:19 PM
