Running starting and running problems the car will start twice and run for 2 seconds
Old Aug 22, 2022 | 08:35 PM
confiocco1@gmail.com's Avatar
Default Running starting and running problems the car will start twice and run for 2 seconds
Hi everyone the car will start twice and run for 2 seconds and then dies on the third time it'll start and run if I turn the key off it won't start then I have to unhook the battery and wait 20 minutes when it starts it runs fine any ideas thanks
Old Aug 22, 2022 | 10:21 PM
exparamedic's Avatar
Default Re: Running starting and running problems the car will start twice and run for 2 seco
https://www.needswings.com/crossfire-skreem-repair
https://www.crossfireforum.org/forum...ps-skreem.html
Old Aug 23, 2022 | 08:42 AM
before you dig into the skreem,,, replace the rcm.
Old Aug 23, 2022 | 09:18 AM
Thanks AMX1397.
I forgot the basics and how many problems the RCM can cause. It should be looked at first.
Old Aug 23, 2022 | 01:05 PM
Originally Posted by exparamedic
Thanks AMX1397.
Jim is the nicest, best guy on the forum, but I disagree.
The SKREEM is powered from pin 3 of the ignition switch, not the RCM. IF you are getting three cranks then nothing, the RCM is powering up the ECU, therefore, the RCM is not the issue.
One of the following is your problem:
1) You changed key fobs and forgot to transplant the little black RFID chip to the new fob. (You'd know if it you did.)
2) You messed with the dash and either damaged the black ring around the key or accidentally yanked the wires from the ring to the SKREEM out of the SKREEM. (You'd know it if you did.)
3) Your SKREEM has failed. (OFTEN happens.)
4) Your ECU has failed. (NEVER happens.)
Old Aug 24, 2022 | 06:12 PM
The SKREEM is powered from pin 3 of the ignition switch, not the RCM. IF you are getting three cranks then nothing, the RCM is powering up the ECU, therefore, the RCM is not the issue. thanks pizzaguy you are the best.
That is the best 4 answers that you can get , Mark you are the best
but when i had that problem i disconnect my batt ,pumped the brake a few times to discharge the system. let my car sit with batt disconnected for about 20 minutes ,fired it up drove home then swapped the rcm,,,no more no start. no problems the only difference i was in My V8 crossfire.
MARTHA64
Sep 1, 2018 04:44 PM
cobra1951f
Mar 12, 2017 11:39 AM
KrisFire
Apr 29, 2016 03:09 PM
nid4u
Sep 1, 2014 04:27 PM
Tomqn1
Aug 11, 2013 08:08 AM
