What tire repair kit are you carrying in your Xfire?
Old Oct 14, 2005 | 09:28 PM
chxf's Avatar
Default Re: What tire repair kit are you carrying in your Xfire?
Originally Posted by Rob M
And, keep in mind Chrysler road side assistance will not repair your tire. The only function they will perform is a tow to the nearest Chrysler dealership.
Yes, that's right. And why do they want us to call the Chrysler Assistance? Because the are willing to help? By that the brand Chrysler always has good results (low numbers) in breakdown statistics of independent national road assistance.
Old Oct 16, 2005 | 03:03 PM
Diardi's Avatar
We just had our first opportunity to use Chrysler Assistance. We have 13,476 miles on the Continental Tires on our 2004 Blaze Red Coupe. We apparently had an inner sidewall failure on the front driver's side tire, but I didn't realize this was the case until after I attempted a repair with the goop kit that came with the car. It wasn't until after emptying the goop cylinder and still not getting the tire to hold any pressure that I called Chrysler Assistance. They located a tow service but because their operator transposed some numbers in my area code, they couldn't call us back to give us the estimate for the tow. My wife and I waited more than an hour and tried calling them again. (Did I mention we were on the eastern side of the Sierra's about 130 miles south of Lake Tahoe, in a very iffy cell zone?) We finally got our approval through -- $400 -- and after our car was on the flatbed truck I could look under the car from the passenger side and see all the goop appearing to come out of the sidewall, at the bottom. Won't know until Monday when I call the dealer again what caused the failure. I'm replacing both front tires because I fear a handling problem if I replace just one. Anyone have any ideas on causes of tirewall failures? I check my tire pressures once a week, so don't think low inflation was a cause.
Old Oct 16, 2005 | 09:20 PM
chxf's Avatar
Originally Posted by Diardi
We have 13,476 miles on the Continental Tires on our 2004 Blaze Red Coupe. We apparently had an inner sidewall failure on the front driver's side tire, [...] Anyone have any ideas on causes of tirewall failures? I check my tire pressures once a week, so don't think low inflation was a cause.
Looks like fault in the material. 13+k miles is far to low to call it regular wear out (normal driving). Take it to your dealer and demand damages.
Good luck.
Old Oct 17, 2005 | 11:18 AM
Black SRT's Avatar
Can you use the pump with out the goop? Because if you pull a nail out you better know for sure that you can air it back up.
Old Oct 17, 2005 | 11:59 AM
danimal's Avatar
Originally Posted by Black SRT
Can you use the pump with out the goop? ...
Certainly.
Old Oct 17, 2005 | 12:06 PM
Black SRT's Avatar
Originally Posted by danimal
Certainly.
Thanks I never did look at it very close. Have any of you guys used the pump? I'm just wondering how powerful it is.
Old Oct 17, 2005 | 01:08 PM
Rob M's Avatar
the air compressor works well. i've used it several times to check pressures and inflate tires on my crossfire and other vehicles. it's powerful enough that in just over a minute it will blow the 20 amp lighter fuse in my olds alero (i don't know off hand what fuse the crossfire uses). you just have to be careful not to run it for too long (as specified in the owner's manual) since it could overheat. but you can fill a completely flat repaired tire in two to three minutes. it can fill tires to pressures in the low-mid 30 lb range (maybe higher but have not verified since i didn't want to chance burning it out). using the compressor along with a tire plug will get you home after most flat tires.
some might wonder why chrysler doesn't just provide the type of tire repair kit we are talking about here instead of the sealant. i think the reason for that is because the sealant, despite it's inferiority to a tire plug, is much less labor intensive and you can keep your hands cleaner since all you touch is the valve cap. even though the instructions for tire repair kits are easy to follow the repair can be difficult or intimidating for some. first, it can be a bit*h to remove things like screws from the tire, provided you can easily find the hole/leak. you don't remove the puncturing object when using the tire fit sealant nor do you need to locate the hole. it can also be difficult to push the plug through the treadwall since you have to force the tools through steel woven belts. i've found that it's best to insert the plug part way then try inflating the tire a bit before inserting the plug fully (it's easier when the tire is pushing back at you).
Old Oct 25, 2005 | 09:31 PM
danimal's Avatar
I found another link tonight that some of you may be interested in:
http://www.stopngo.com/plugger.asp
They have a couple of nice little kits that aren't expensive and may just get you out of a tough situation.
Old Oct 25, 2005 | 11:17 PM
ben47's Avatar
$31.00, kind of expensive. You can buy almost the same type of kit in any auto store for way less than half that amount.
Old May 29, 2008 | 07:06 AM
I got a $8.99 tire plug repair kit at Walmart.
It fixed a tire at the Dragon meet and the car went on to South Carolina and back to Canada with no problem.
Old May 29, 2008 | 09:10 AM
Stogey's Avatar
Sounds as though you have a much better service there than we do here in the States. Hope you don't ever have to use it...but if you do...inquiring minds want to know!!!
Considering Switzerland is about the size of what ? Rhode Island ?
They should !
Just my Dos Centavos !
Old May 29, 2008 | 12:52 PM
jackei's Avatar
+1 vote for the tire plug repair. It is cheap and reliable.
One time I fixed 3 nails at the same time on the same tire, no leaks and runs like new.
One time the tire picked up a screw driver (I don't know how, but it did) It was thick as a pen, and I fix with regular tire plug as usual, no leaks and keep running like new afterwards.
luckily both cases happened on my old car, not the crossfire.
Old May 29, 2008 | 02:29 PM
Chris2806126's Avatar
I ordered the professional tire repair (plug) kit from JC Whitney just in case I got a small puncture along the road. Fits perfectly in the well on the opposite side of the trunk from the air pump. IMO I would rather plug the tire than fill it with goop.
Some how professional and JC Whitney in the same sentence don't seem to go together.
Old May 29, 2008 | 06:18 PM
+fireamx's Avatar
Is this the "type" of sidewall failure that you are talking about?
https://www.crossfireforum.org/galle...php?photo=2637
Old May 30, 2008 | 01:39 PM
cmcghee559's Avatar
Smile Re: What tire repair kit are you carrying in your Xfire?
I do not carry anything but a spare https://www.crossfireforum.org/forum...ght=spare+tire
PNA
Nov 12, 2020 04:44 PM
Kodebuster
Nov 5, 2020 04:06 PM
massanu
Feb 20, 2019 07:06 PM
xfireon20z
Jul 20, 2015 04:35 PM
UNDER PSI
Jul 18, 2015 02:12 PM
