Battery Cut-Off Switch ???
Old Dec 24, 2010 | 02:05 PM
a12rag's Avatar
Default Battery Cut-Off Switch ???
Hi all . . .was looking at a xfire ragtop, and noticed the owner had a battery cutoff switch wired into the negative battery cable. The guy said he was selling the car for his girlfriend, so didn't know much about it . . . . . I am concerned that there are electrical issues that someone did not figure out. Figured it would be easier to turn off the battery, rather than track down a draw on the battery . . . . how much do you think it should affect the value of the car ???
Could take HOURS to try and figure out the problem I am thinking (maybe like $1k worth off the price ???)
Your comments are appreciated . . . .
Thanks,
Mark
Old Dec 24, 2010 | 03:27 PM
TiredRetired's Avatar
Default Re: Battery Cut-Off Switch ???
Originally Posted by a12rag
[IMG]file:///C:/DOCUME%7E1/MARKLI%7E1/LOCALS%7E1/Temp/moz-screenshot.png[/IMG][IMG]file:///C:/DOCUME%7E1/MARKLI%7E1/LOCALS%7E1/Temp/moz-screenshot-1.png[/IMG]Hi all . . .was looking at a xfire ragtop, and noticed the owner had a battery cutoff switch wired into the negative battery cable. The guy said he was selling the car for his girlfriend, so didn't know much about it . . . . . I am concerned that there are electrical issues that someone did not figure out. Figured it would be easier to turn off the battery, rather than track down a draw on the battery . . . . how much do you think it should affect the value of the car ???
Thanks,
Mark
Don't you just love the ignorant seller story line. "I'm selling this and I know nothing!"
There's a problem there, count on it.
Old Dec 24, 2010 | 03:34 PM
a12rag's Avatar
Yup, that is what I am thinking . . . . gonna get the car checked out for sure, prior to purchasing . . .
Old Dec 24, 2010 | 04:14 PM
Kodebuster's Avatar
Make sure to check the car for any codes...if you could have access to the car for a few days...that might help...especially if your dealing with an intermittant electrical issue.
If it's a solid problem it can be fixed...it's the intermittant ones that will make you berzerk...and can put a damper on your permagrin...!!!
Old Dec 24, 2010 | 05:08 PM
waldig's Avatar
Talking Re: Battery Cut-Off Switch ???
Its Easy, get a small light bulb rated at 12volts and connect it with clip leads across the battery switch. If it stays lit there is a drain on the system. If it blinks and goes off the issue is not a continuous PHANTOM drain.
Just a thought I have cutouts to allow charging and preventing the car from being hot when I work on the wiring without pulling the battery terminal. Its also a theft deterrent, so it might be a no big thing.
Woody
Old Dec 24, 2010 | 05:30 PM
a12rag's Avatar
True, but it is a stock car, owned by a woman (not that, that should have any bearing . . . but. . . ) . . . I just get the feeling there is something up with this car . . . course I need explanation from "her" as to why the switch was added - what problem did she have ? Or what was she told that she should have that added . . . . . . call me a cynic . . . but hey, if I could get the car cheap enough . . . maybe I wouldn't worry either ???
Old Dec 24, 2010 | 05:59 PM
Just curious but if the battery is disconnected, wouldn't everything need to reset each time it is reconnected? I know a bad or old battery, in these cars, causes all kids of issues.
Old Dec 25, 2010 | 08:25 AM
bluecoupe's Avatar
I can't speak to the car in question however I purchased my Limited from a Chrysler Dealer who took it in on a lease return. It has a quick disconnect on the neg cable. I had never seen anything like it before. Turns out there is another forum member who has one on his car too. He purchased it new and from what I understand it was on the car when he got it. From what I can surmize some Dealers added it for security reasons. I used it when doing electrical installations.............very handy and I have never needed to reset anything when hooked back up.
Old Dec 26, 2010 | 12:30 AM
I can't speak to the car in question however I purchased my Limited from a Chrysler Dealer who took it in on a lease return. It has a quick disconnect on the neg cable. I had never seen anything like it before. Turns out there is another forum member who has one on his car too. He purchased it new and from what I understand it was on the car when he got it. From what I can surmize some Dealers added it for security reasons. I used it when doing electrical installations.............very handy and I have never needed to reset anything when hoked back up.
Not even the ESP light?
Old Dec 26, 2010 | 08:34 AM
bluecoupe's Avatar
Dave, I've never done an ESP re-set and I've had the battery on both cars disconnected numerous times. The Nav's do need to re-calibrate, but no help from me needed, they do it on their own.
Osusannah
Feb 12, 2024 01:49 PM
blackpepper
Oct 4, 2017 06:09 AM
Reliableron
Oct 17, 2015 10:19 PM
o55ie18
Oct 5, 2015 05:50 PM
Valk
Sep 17, 2015 11:43 AM
