if it's not one thing its another
Old Feb 25, 2011 | 02:26 AM
valiant106737's Avatar
Default if it's not one thing its another
Gday again. I got the car booked in for them to have a look on march 9th. I am hoping it is still under some sort of warranty as the previous owner indicated that she was taking it back to her dealership in Victoria almost right up until we bought it off her last December.
Any way I have another problem is that both powered seats are not working now. Twice now I had this problem only to find that they suddenly work again. Just now I got in it to move it out of the garage and, guess what, the seats are not working again! My wife is starting to worry that we bought a lemon, but me, it will take a lot more than these minor things to put me off . Any suggestions ? Thanks Dave.
Old Feb 25, 2011 | 07:59 AM
maxcichon's Avatar
Default Re: if its not one thing its another
They ONLY work if the doors are both closed.
Does that help?
Old Feb 25, 2011 | 09:54 AM
SNAKEWOLF's Avatar
Try this https://www.crossfireforum.org/forum...ght=power+seat
good luck
Old Feb 25, 2011 | 10:01 AM
Does that help?
My seats only move if:
1) The door is open (this is so you can move the seat and get your spare shirt out from behind the seat - I guess.)
or
2) The ignition is on.
Old Feb 25, 2011 | 01:45 PM
Ed Mahoney's Avatar
check & change fuses !!! Sometimes they heat up just enough to open & shut off power without breaking !!! My turn signals did that to me !!!
Old Feb 25, 2011 | 02:08 PM
mdaniels4's Avatar
or
What??? Then I must have the special one, because my seats move anytime, with the doors open and the key out of the ignition, as I have vacuumed behind the seats or looked for loose change many times.
My bet is a relay or the fuses since both won't operate except sporadically then a relay comes to mind first
Old Feb 25, 2011 | 03:26 PM
Bladecutter's Avatar
The drivers seat will work for a minute or two after opening the door.
After that, you have to turn the ignition to the ON position to get them to move, if you don't want to close, and then re-open the door.
This is the behavior on Bat's '08 Convertible.
BC.
Old Feb 25, 2011 | 06:14 PM
BC.
Not on my car I have found out, mine do not time out at the same time as the interior lights do if you leave a car door open. The interior lights are controlled by the BCM, the seat solenoid is not.
If they are properly working the seats can be adjusted any time, ignition on or off, doors open or closed.
If they only work when the doors are open then the diode indicated in the photo below has failed.
If they only work when the doors are closed then I would hazard a guess that the diode laying alongside the diode indicated in the photo below has failed.
The diodes cost $1 for ten, the relay costs $15 to $20 plus. You have to tear out the trim either way.
The Relay part number is;
MB #002 542 22 19
Siemens Part #72KD305
and mystery numbers, PA6-GF30 and A430303
The diode part number is SM4007 - SM means surface mount.
I replaced mine with part number 4007 - these come with a wire at each end.
I bent the wires and soldered them to the board keeping the diode flush with the board so that it still fit inside the relay housing.
Seat relay removed from housing.
Trim removed to expose seat relay.
Last edited by onehundred80; Feb 25, 2011 at 09:33 PM. Reason: Found out I was in error on seat time out.
Old Feb 25, 2011 | 07:27 PM
Default Re: if it's not one thing its another
The driver's seats in both our Crossfires operate without the key in the ignition and the door open.
Old Feb 25, 2011 | 07:48 PM
I just did a test on both cars. I left the doors open until the interior lights went out. They were open for about 20 minutes and found that the seat controls still work.
Hope that helps.
Old Feb 25, 2011 | 09:13 PM
Hope that helps.
Mine do the same....I take the key out so don't have to listen to the chime while cleaning...
Old Feb 25, 2011 | 09:28 PM
Hope that helps.
I did this test when I repaired the relay and I was certain that they did not work, just tried it and they do still work. The interior lights use the BCM and the seats do not I found from the circuit diagrams.
That relay will get quite warm after a while, I could feel it get warm when I was monkeying around with it.
I'll modify my previous post.
Old Feb 26, 2011 | 01:14 AM
Question Re: if it's not one thing its another
thanks for all the responces. after taking it out for a cruise last night the seats worked after about 15 min driving, which was a relief as I am 6ft tall and it was on the wife setting, she is 5'6' tall.
I had a look at the relay thread, I will Have a look under the dash. One question though, seeing I got right hand drive, would the relay be on the other side to yours?.
We are just about to go on a Chrysler cruise I wonder if the seats will work!?. Dave
fastfred
Nov 5, 2018 09:47 AM
rmcdaniel12
Nov 4, 2015 04:08 PM
Oct 1, 2015 01:42 AM
Sep 28, 2015 07:40 PM
debradegiovanni
Sep 27, 2015 09:39 AM
