Fuel Filter at Fault?
Old Feb 20, 2013 | 09:06 PM
rozinante's Avatar
Default Fuel Filter at Fault?
I have yet to remove and replace my fuel filter and my mileage is almost 90,000. Now I have to wonder if this is causing the car to suddenly die without restarting for several minutes or up to an hour. When it does restart I get a CHECK ENGINE light, but that goes away by the next day. I have not checked the code(s). This has happened to me two times within two weeks. Can a fuel filter going this long mess up the fuel management system and cause a shutdown?
thanks
2004 coupe
Old Feb 21, 2013 | 06:37 AM
bluecoupe's Avatar
Default Re: Fuel Filter at Fault?
Don, my guess would be your CPS................
https://www.crossfireforum.org/forum...on-sensor.html
Old Feb 21, 2013 | 06:59 AM
Doubtful it is the fuel filter. But I would get it replaced due to mileage, before or after you get the issue resolved.
Old Feb 25, 2013 | 10:41 AM
gfalcone's Avatar
Highly recommend you replace the filter.. the filter is flow/no flow issue even after half hour.... I realize there is/maybe "flow by" where the gas leaks enough through to start the car but you won't get far if that's the issue. Look into the Crankshaft Position Sensor. it's well known issue on these cars...
Old Feb 25, 2013 | 01:49 PM
waldig's Avatar
Talking Re: Fuel Filter at Fault?
HOSES TOO !!!!!!!!!!!! Woody
syfi
Mar 28, 2026 04:14 PM
Valk
Jun 22, 2025 09:15 PM
TerryR
Dec 13, 2019 03:27 PM
jimf
Oct 10, 2015 10:22 AM
DaveMe
U.K.
Sep 29, 2015 08:09 AM
