Which sensor
Old Dec 19, 2018 | 02:36 PM
Default Which sensor
Does anyone know what sensor, when putting the top up, tells the pump to stop when it is in the full up position? Mine stops but does not beep. I can still latch the top and the switch light stops flashing. When I unlatch the top, the windows only go down about three inches and stop. If I then push the top down switch the windows go down the rest of the way and the switch light comes on but there is no movement or beeping. If I relatch the top the switch light stays on and I cannot open the trunk until the pressure bleeds off. If I unlatch the top and push the button for top up the pump runs for a brief second and the top moves closed for about 1 second. If I then latch the top the switch light goes out and I can open the trunk. It seems as if the top stops just shy of being fully raised. It doesn't seem to really complete the cycle. I have tried re syncing the top with no different results. I have been manually putting it down and putting it up the normal way.
Any thoughts or suggestions would be appreciated. It has to be a sensor issue. Could it be one on the cylinders?
Thanks
Old Dec 19, 2018 | 03:51 PM
Default Re: Which sensor
I"m thinking sensor on a cylinder, but I gotta say, the "windows go down three inches" thing has me scratching my head.
Let me ponder this one for awhile. And if the car has spent much time out in the rain, yank the trim outta the trunk and look for water intrusion.
Old Dec 19, 2018 | 05:42 PM
Definatly no water intrusion. Thank you for any thoughts you have. It has me scratching my head as well. I still think it has to do with travel.
Old Dec 23, 2018 | 05:08 PM
Okay, possibly one more clue. When I am putting the top up using the top button, it goes up as it should but starts beeping when to bow starts to come up for the tonneau cover to close and beeps until the top stops moving???
Old Dec 28, 2018 | 03:54 PM
Well. I just resigned myself to living with a top that must be put down manually and up hydraulically. There does not seem to be a solution.
pizzaguy
May 23, 2014 07:33 PM
bionicdriver
Nov 1, 2012 05:10 PM
boboridesbmx
21
Feb 24, 2012 06:44 PM
mhoward0058
Feb 6, 2012 07:42 PM
chaotictaco
Apr 6, 2011 10:01 PM
