Roof - Top indicator Blink
Old Aug 1, 2021 | 06:27 AM
sunman's Avatar
Default Roof - Top indicator Blink
Hello to everyone.. I need your help.. suddenly my roof start to move slowly and got stucked.. I bought the car two weeks ago and it is at 24.000 miles.. the roof open button indicator blinks after I closed the top.. please kindly inform me what does the button indicator want to tell me .. what’s my problem..
Old Aug 1, 2021 | 06:30 AM
Default Re: Roof - Top indicator Blink
First thing I would check is the fluid level in the pump reservoir.
It is located behind the paneling in the left rear luggage compartment.
Old Aug 1, 2021 | 06:41 AM
sunman's Avatar
if it’s low.. what specs should I use to replace the oil or which oil ? By the way thanx for the quick and kindly reply..
Old Aug 1, 2021 | 11:14 AM
there are low and hight markings on the reservoir, use Pentosin CHF 11S
( a turkey baster works pretty good )
Old Aug 1, 2021 | 02:06 PM
sunman's Avatar
Sorry but I couldnt find the oil measurement cap or sonething.. you told it’s in the trunk and left side, behind the driver.. can you please kindly send me a link that I could see where it is..
Old Aug 1, 2021 | 03:51 PM
sunman's Avatar
The blink has stopped and I realized this event occured after the car wash.. Can it be relevant to the car wash ? Do you have any experiences about that ?
Old Aug 1, 2021 | 11:28 PM
The blink means the cycle did not complete when you moved the top the last time. This can be simply due to letting go of the button before the beep.
Other than that, you either have low fluid or a pump going bad, based on the slow movement.
The tank is on the pump assembly, driver's side wheel well, back by the tail light assembly. Hit the button to put the top up or down, when the big lid raises, let go of the button and you can look down in there.
Old Aug 1, 2021 | 11:36 PM
Tank is not visible here, but it's at the location shown, it's hiding behind the Top Control Module.
Old Aug 2, 2021 | 06:02 PM
If I remember correctly, the level is read through the side of the semitransparent bottle (tank), there is no cap level bar in the cap. If there is one, this is the first I heard of it. Good luck!
Old Sep 1, 2021 | 03:09 AM
sunman's Avatar
hello everyone again.. we understand that the right main hydraulic lifter is broke.. do you know where can I order this part. I want to buy brand new.. please kindly share a link if you know the shop.
thanks again..
Old Sep 1, 2021 | 10:08 AM
Top hydraulics rebuilds them. To my knowledge no new ones are available.
Old Sep 1, 2021 | 10:11 AM
sunman's Avatar
Thanx for the reply.. Cause I live in Turkey, they werent my first option because of the delivery time.. lets see if I may find another solution..
Old Sep 1, 2021 | 12:27 PM
Parts like those are hard to find, and this problem is, as I look at it, part of the "charm" of our cars.
Best of luck to you, sunman.
Old Sep 1, 2021 | 02:07 PM
They are on E-bay however buying used is a crap shoot.
Simoninky
Aug 13, 2018 08:27 AM
revs01
Dec 31, 2017 09:22 AM
CoolPenguin
May 22, 2014 04:25 PM
Spyder3000gtVR4
Jul 27, 2013 02:46 PM
kylestocks
Jun 30, 2011 07:20 PM
