Convertible top rubber seals
Old Feb 25, 2024 | 03:00 PM
Kernol's Avatar
Default Convertible top rubber seals
I have a 2006 Crossfire Roadster . One of the rubber seals on the top keeps popping off when I put the top down. I can put it back on when I put the top up partially, stop the process, push the seal on and hold it while I press the button for the top to continue going up. Needless to say, a pain in the ***. It is on the passenger side right on the rear of the mechanism where the top breaks to straighten. I cannot find any schematics in the manual or on line to determine what seal to order. Any thoughts?
MODERATOR NOTE:
Do not post tech help requests in the "New Member Introduction" forum. Thread moved, re-direct expires in four days.
Old Feb 25, 2024 | 03:33 PM
Default Re: Convertible top rubber seals
YOu can't order those seals, you can't order most any body part for these cars. If the seal is bad, you've got to fo find a junked roadster somewhere and get the part off it. But here is my advice: It is up to YOU to take a GOOD LOOK and determine what is wrong. (Or take it to any DIY person who is observant and somewhat "mechanical" and pay them to look at it.)
MANY of us have dealt with this: You are not seating the seal correctly.
Mine was fine, then we replaced the top. Right away, it kept popping out. It took me maybe five tries over three months before I finally got it to sit in there and stay. I got sick of what has to be something simple, and finally reseated the damn thing in the following position, where I could tell how it was seated, then watched it as the top went thru the cycle to see when it was popping out and what was causing it. I can't remember, it was over two years ago, but I saw how I had it positioned incorrectly and reseated it.
It's been fine ever since.
YOu seat it with the top in this position and then cycle the top and watch what is happening, that's all I can remember:
Old Feb 25, 2024 | 10:30 PM
dcskmail's Avatar
deleted
nickwe21.
Jul 29, 2022 03:31 PM
kernol2
May 13, 2022 07:38 AM
KeithTexas
Nov 1, 2017 03:06 PM
Rets
Dec 7, 2013 04:59 PM
Learnin
Aug 31, 2010 12:34 PM
