"Clicking" noise when tranny put into Reverse
Old Jul 3, 2007 | 01:18 PM
vegassrt's Avatar
Default "Clicking" noise when tranny put into Reverse
Just wondering if this is normal...the clicking noise (can hear it clearly) usually happens only on a cold start when putting the transmission into Reverse from Park...is this normal? Also it seems the transmission goes into Reverse a bit harshly when parked on an incline (such as a sloped driveway)...the car shifts fine when running.
Old Jul 3, 2007 | 01:43 PM
AMGLover's Avatar
Default Re: "Clicking" noise when tranny put into Reverse
Message Deleted
Old Jul 3, 2007 | 03:31 PM
SRT SIX's Avatar
Same thing mostly always when cold or first started. One metallic click (snap)...
Old Jul 3, 2007 | 04:51 PM
vegassrt's Avatar
I'd say one click...kinda sounds like something metallic popped...I think it comes from center/rear of the car.
Old Jul 5, 2007 | 04:43 PM
AMGLover's Avatar
Message Deleted
Old Jul 5, 2007 | 07:59 PM
SRT SIX's Avatar
Originally Posted by AMGLover
Ah you need P.M. (preventive maint) on the e-brake linkage and springs. Simple dealer work.
AMGLover,
You may be right (you have been about many other things) but I think it is something other than the e-brake. It only does it after shifting into reverse upon cold startup (left overnight). I almost never set the handbrake and it only does it going into reverse. If I put it in D (skp R) it doesn't do it. Once the car has been driven, it doesn't do it again all day.
Old Jul 5, 2007 | 09:02 PM
crossfirefun's Avatar
Well I paid attention and mine does it also from a cold start into reverse. I don't think it is a problem as my car only has 500 miles on it. Just a simple clink like a drive shaft u-joint thats needs lube or is worn. If it is a problem I hope we find out before it gets to be expensive.
Old Jul 6, 2007 | 12:18 PM
AMGLover's Avatar
Message Deleted
Old Jul 6, 2007 | 12:20 PM
AMGLover's Avatar
Message Deleted
Old Jul 6, 2007 | 01:34 PM
SRT SIX's Avatar
Hoy Hoy! I have a roadster so with the top down I hear it better and you will be surprised to find out that it will do it for the first couple of stops going forward.... but it is much softer. Let's look at the situation; what is the last thing that you do when you park the car...release the brake pedal. Now the e-brakes are in the back side of the hub and are subject to lots of heat..heat makes things expand...expanding things push on other things. The e-brake is the old drum brake setup that relies on springs and things to keep thoses shoes off the drum. Additionally 99.9% of your stops are moving forward so rotational stress moves it in that direction.
Fast forward to next morning. Everything is cool and contracted back into position, you switch direction and the stuff that stuck together gets forced into the oposite direction - popping it loose- as oppose to grinding it loose going in the same [forward] direction. Maybe it's a caliper that needs to be lubed, but I still think it is more prone to be the e-brake...either way it needs some lube/check for tolerences.
whatcha think?
Hey, it worth having checked. Unfortunately this is one of those "....it only happens when...." issues. Experience with the (insert the brand of choice) service personnel, is if it doesn't happen the first time it is tried, the problem simply doesn't exist!
Thanks,
Old Jul 6, 2007 | 01:47 PM
vegassrt's Avatar
Hopefully if other cars are doing it, the clicking noise is normal...I have noticed sometimes it is one click and sometimes 2 when going from Park to Reverse on a cold start...I'll ask the dealer but given I had to diagnose the IC water pump for them (after they put in new supercharger and said opps that did not fix the problem), I'm not optimistic they'll have a clue...
Old Jul 6, 2007 | 02:15 PM
AMGLover's Avatar
Message Deleted
Old Jul 6, 2007 | 06:38 PM
lewy xfire's Avatar
my car does the same thing also.
Old Jul 6, 2007 | 08:20 PM
distantpulse's Avatar
Mine does this also...I honestly don't think it's anything to be worried about.
Old Jul 6, 2007 | 11:21 PM
Schrudds's Avatar
I also hear a clicking sound which can be a long as 10 seconds when I start the car prior to backing out of my garage. This clicking sound does not happen all the time.
Old Jun 15, 2012 | 11:51 AM
jlw's Avatar
jlw
I have a manual and my car does the same thing. Sound like your staring the car while the car is running (not as loud). Do the brakes still make an ajustment when backing up?
Old Jun 15, 2012 | 01:05 PM
The Beep's Avatar
It sounds like a solenoid.
Either brakes? Theft deterant device? Our cars have so many wierd little gizmo's.
I've always figured it was normal and if everyone else is hearing it, well...
Old Jun 15, 2012 | 07:55 PM
Coyote's Avatar
I have noticed this clink noise since I bought my car. It does not always make that noise in the
morning, but many times it does. I've put 107,000 miles on the clock, and I've always been a
little worried about that noise, but no problems so far.
Old Jun 16, 2012 | 02:27 PM
BLACKSRT-6's Avatar
I recommend checking the rear axel nuts. They come loose and spin just a little, then klink.
usprb1976
Apr 4, 2024 04:57 PM
nataliefs
Oct 5, 2015 01:03 PM
skeet370
29
Sep 18, 2015 05:53 AM
steps
Sep 12, 2015 09:23 PM
RiderJC
Sep 7, 2015 11:19 PM
