Sloppy transmission
Old May 8, 2008 | 05:15 AM
Benflitv's Avatar
Default Sloppy transmission
When I park on even a slight grade, once I let off the brake, the car will roll two to three inches in either direction. I would figure that a "built" tranny wouldn't have much play at all. It would be tight and solid. Anyine experience this? Think it's normal? Or now a sure way of telling a tranny is going bad or not? Cause I always smell this hot smell from my car (stock) once I park it. Just smells like hot metal, somewhat similar to when you go into a welding shop. Just not as strong. I am hard on it, but it's not overheating and all fluids check nominal.
I have no idea about either issue. Car has 6k on it.
Ben
Old May 8, 2008 | 09:23 AM
VetteVert's Avatar
Default Re: Sloppy transmission
All current automatic transmissions have a parking pawl (kind of like a pin) that engages a gear on the output shaft to stop motion. The car can have to roll forward or backward a bit so that it can engage...I would think you would have noticed this on all autmomatics...nothing wrong with the tranny based on it rolling a bit before the pawl can engage.
VV
Old May 8, 2008 | 10:56 AM
huudoo's Avatar
mine will do that , i would not worry about it
just make sure when u first start the engine
let the car warm up for a few min to prevent slippage
Old May 8, 2008 | 11:04 AM
calxfire's Avatar
Also when you engage the parking pawl like that it makes it hard to take out of Park when you're ready to go. That's the reason I use the parking brake all the time. I am not saying it will damage the transmission by just shifting it into Park because it was designed to hold the weight of the car but that binding when you take it out of Park can't be good for it either. But that's just me.
Old May 8, 2008 | 11:38 AM
Jeep2Xfire's Avatar
Only thing with that pawl is that as far as the transmission is concerned "Park" and Neutral" are the same gear, only difference is that pawl. It's a pin that's about 1/8" in diameter that holdss your 3100lb car still. Best practice is to have foot on service brakes, engage the parking brake, then shift into "Park" so that pin sees as little shearing force as possible.
Justin
Old May 11, 2008 | 06:13 AM
Benflitv's Avatar
Is it something with the computer that makes it slip right out of the gate or fluid? I've hit it hard a few times out of the gate and had it slip. It feels like it goes right into neutral and have to stop, shift to park, and then drive again. First time it happened I thought I lost the tranny all together. It's tempting cause the SC isn't heat soaked and feels much faster than when hot.
Ben
Old May 11, 2008 | 06:52 AM
maxcichon's Avatar
Justin
This procedure is an ABSOLUTE MUST for any automatic tranny.
syfi
Mar 28, 2026 04:14 PM
UNDER PSI
Nov 1, 2015 09:39 PM
Oct 1, 2015 01:42 AM
rfourt
Sep 25, 2015 01:38 PM
atdavis2
Sep 21, 2015 01:25 PM
