Alignment Questions??
Old Feb 9, 2009 | 10:06 AM
rodimus's Avatar
Default Alignment Questions??
I have my Crossfire SRT6 in for a alignment at a tire shop and was told the front is off about a degree, whatever that means.
He said that might be how it came factory because of the type of car it is, and mentioned something about casters....?
Sorry I don't have much detail but I just spoke briefly on the phone.
What is a caster and does that apply to the SRT6?
Does this sound right?
TYIA
Old Feb 9, 2009 | 11:10 AM
naudi90's Avatar
Default Re: Alignment Questions??
The guy was saying the tire was off one degree from spec. Here is an article that helped me understand the terms when I had my alignment issue. Still have that issue, lol!
http://www.familycar.com/alignment.htm
To adjust the front alignment I am pretty sure you need new bolts.
Old Feb 9, 2009 | 12:00 PM
rodimus's Avatar
Is the camber a part? Or is it something that you can adjust?
It is to my understanding that if the camber is off your wheels will have uneven tread wear.
Old Feb 9, 2009 | 12:35 PM
naudi90's Avatar
From the article:
Camber is the angle of the wheel, measured in degrees, when viewed from the front of the vehicle. If the top of the wheel is leaning out from the center of the car, then the camber is positive ,if it's leaning in, then the camber is negative. If the camber is out of adjustment, it will cause tire wear on one side of the tire's tread. If the camber is too far negative, for instance, then the tire will wear on the inside of the tread.
Old Feb 9, 2009 | 12:36 PM
rodimus's Avatar
I remember seeing OEM alignment specs for the car I can't seem to find the documentation, any help???
Old Feb 9, 2009 | 12:52 PM
naudi90's Avatar
Here ya go my good man
http://homepage.mac.com/gregmeach/XFire/
Look under the Suspension manual
rodimus's Avatar
Originally Posted by naudi90
From the article:
I found the documentation and it it looks like -1.22 for the front and -1.13 for the rear is correct.
Hopefully it does not go beyond that. I've been reading the alignment info on here and looks like they sell camber adjustment bolts for around $20.00 a peice...... I think that should fix the problem if there is one.
Does this sound correct??
Old Feb 9, 2009 | 12:54 PM
naudi90's Avatar
This is exactly what I am having Carmax do to fix a pull I have.
I had them order these bolts (I think its two per each front tire) to install.
Old Feb 9, 2009 | 01:06 PM
rodimus's Avatar
Does that price seem accurate?
What are they charging for all the work?
I brought it to a tire shop that couldn't do camber adjustments but still want to charge me full price...... is that normal?
Old Feb 9, 2009 | 01:07 PM
rodimus's Avatar
THANKS!! and Thanks Again.
(wasn't enough characters)
Old Feb 9, 2009 | 02:08 PM
ProjectMayhem's Avatar
Is that for all models does the srt-6 have same specs?
Old Feb 9, 2009 | 06:23 PM
naudi90's Avatar
Good question. I'm not positive yet but this is an interesting thread on the subject:
https://www.crossfireforum.org/forum...alignment+spec
Old Feb 10, 2009 | 06:16 AM
rodimus's Avatar
Does part number 5140876aa adjust up to 1 degree? At http://www.chryslerpartsdirect.com
Is it for just the fronts, are the rear too?
How many need to be ordered for a full camber adjustment?
Old Feb 10, 2009 | 08:10 AM
rodimus's Avatar
Update:
There is no update at this time, (except) I have my alignment readout and just need about 1 degree of adjustment for the front camber?
TerryR
Dec 13, 2019 03:27 PM
jimf
Oct 10, 2015 10:22 AM
2005 Ragtop
Oct 3, 2015 03:01 PM
Charlesl
Sep 30, 2015 10:46 PM
brandoni
Sep 30, 2015 07:48 PM
