Noise from engine
Old Jun 2, 2009 | 10:23 AM
Jake80's Avatar
Default Noise from engine
I have only had my SRT about 4 weeks. Noticed that sitting at idle in gear I can hear like a muddled tick/knocking noise. Seems more pronounced when it is sitting at a light and less when I put it into neutral. Does not sound like valve noise.
Took it into Chrysler dealer this morning. Mechanic listened to it. Said it sounds normal for that type of car. It seemed less when we had the hood open rather than in closed postion. He said it could be anything eg: even noiser fuel injectors.
Anyone have any thoughts. Hard to describe noise in an email.
Realize I can turn up the radio louder like my daughter does.
May thow in a bottle of fuel cleaner to see if that helps injectors?.
Car seems to run strong and idle is good.
Thanks,
Jake80
Old Jun 2, 2009 | 11:52 AM
///SilverSaphRT6's Avatar
Default Re: Noise from engine
Yeah it is normal....Mercedes engine is all that it is. All sound like they are ticking sort of like the old Mercedes diesel cars.
Old Jun 2, 2009 | 11:56 AM
Jake80's Avatar
Thanks for your input. Come to think about it. It does sound a bit like a muffled diesel sound that you hear on those type of cars. Of course not that loud.
I know that all cars have their own unique sounds. Not having another SRT around to compare to. Thanks for your input.
Enjoying the car and have a few minor mods on the way.
Jake80
Old Jun 2, 2009 | 12:10 PM
No problem....I thought the same thing when I got mine. Then I thought about it being a Mercedes and knew there wasn't anything wrong.
Old Jun 2, 2009 | 12:19 PM
velociabstract's Avatar
Mine makes the same noise and has from new. I was thinking it was a faulty catalytic converter.
Les
Old Jun 2, 2009 | 01:04 PM
SRT6-Man's Avatar
It should sound like a Sewing Machine.. A light ticking sound is normal and Healthy!
Old Jun 2, 2009 | 08:23 PM
cgocifer's Avatar
I worried about this and still do on occasion. I've heard others that are quieter and some that are louder. Mine is more pronounced on the driver's side. There is also a little black canister just off of the driver's side wheel well that is used for emissions. It ticks also which adds to the rest of the noisy engine. Our SRTs are hand assembled too, so i'm not too concerned.
Old Jun 3, 2009 | 12:24 PM
Jake80's Avatar
Thanks to all for your input.
I agree the motor should be bullet proof and just have to get use to new noises.
Jake80
Old Jun 3, 2009 | 12:35 PM
rodimus's Avatar
It's just your engine knocking on the hood, trying to get your attention to press the gas.....
Old Jun 3, 2009 | 04:24 PM
Montana Crossfire's Avatar
I have to question why this should sound (even in the wildest imagination) anything like a muffled diesel?
It is not and has never been associated with Mercedes Diesels.
The fact that it changes when in neutral indicates the ticking merely is directly associated with RPM.
BMW started out building air planes so should a BMW sound like one of their old fighter planes???
Yes, I do ***** and rant alot (so I have been told) but where does some of this logic or should I say LACK of logic come from?
Jake, I hope this helps you to realize it is to your benefit to accept automobile advice from some members with a grain of salt.
Mike
Mike
Old Jun 3, 2009 | 04:44 PM
Jake80's Avatar
Montana,
First of all I have thick skin and can take input. Good advise as well as bad.
It is hard to describe a noise. Was just wondering if any others had similar noises. Sounds like some do and some do not.
When I can meet up with a few local SRT's I can compare the sound.
Thanks for the input that is why I joined the forum.
Jake80
Old Jun 3, 2009 | 07:24 PM
cgocifer's Avatar
Well, because it sounds like a diesel. Most of it is the use by Mercedes of noisy fuel injectors. Fuel injectors are like tiny little pumps. These happen to be noisy.
Old Jun 4, 2009 | 06:49 AM
Goldwing's Avatar
I've noticed a small amount of valve lifter noise, which tends to go away after the engine warms up and oil circulates. There also was another post about a solenoid or some such on the engine that clicks. I think it was part of the emissions system. It's a heck of a lot quieter than my 63 Buick or 82 Jeep engines!!
Old Jun 4, 2009 | 07:06 AM
Jake80's Avatar
Thanks again for your input. I am sure this is just a normal thing with this type of motor.
Jake80
Old Jun 4, 2009 | 08:46 AM
LOL...I agree. What else do you need explained Montana.
IGot2P
Jul 26, 2025 12:40 PM
massanu
18
Nov 23, 2015 08:52 AM
velociabstract
15
Sep 7, 2015 03:43 PM
yorxs
Aug 18, 2015 07:21 PM
Tp'sfury
Aug 13, 2015 08:20 PM
