Pulley Saver Kit
Old Aug 17, 2009 | 07:41 PM
  #61 (permalink)
jturkel's Avatar
Default Re: Pulley Saver Kit
Originally Posted by 32krazy!
i have looked at this unit for quite a while now. no way to get the stud out. its installed before the spring assy is installed. i finally have a c3 on the way so i guess im gonna bite the bullet and order a new tensioner
if you loosen up the nut, cant you take off the entire assembly? and then somehow remove the stud? or is that not an option? my tensioner pulley's torx stud has a little grip left and isnt totally stripped so can probalby handle a little bit more, but not enough to put the belt back over with the 185
Old Aug 17, 2009 | 07:48 PM
  #62 (permalink)
32krazy!'s Avatar
the nut only removes the pulley. behind the idler pulley and below are 2 more torxes that have to be removed to get the tensioner off the front of the engine. the tensioner spring loaded section is behind the rear of the torx bolt and i dont see any way to get the stud out to replace it
Old Aug 17, 2009 | 08:19 PM
  #63 (permalink)
NeedsWings's Avatar
i just got off the phone with the benz dealer, the tensioner assembly lists at $305 and there is stock in the USA on them. we can get them a little cheaper with our discount but by the time we ship it to you it may be more beneficial to get it locally quicker.
Old Aug 17, 2009 | 08:24 PM
  #64 (permalink)
70GT6's Avatar
Goodyear replacement part # 49262 is about $140 and has updated the adjuster to remove the E10 and replace with a standard fitting.
(Amazon has them for $138, free shipping)
Old Aug 17, 2009 | 08:26 PM
  #65 (permalink)
jturkel's Avatar
interesting. do you have a link to the goodyear link by chance?
Old Aug 17, 2009 | 08:28 PM
  #66 (permalink)
MikeR's Avatar
I just tried to take that stud out of my old tensioner and no luck. I even used a 3 foot breaker bar. I dont know what they used to put it in, but I felt like I was going to break it trying to get it out. The only good thing about the $197 bolt is that it comes with a tensioner and new pulley!
Old Aug 17, 2009 | 08:31 PM
  #67 (permalink)
70GT6's Avatar
Goodyear® Engineered Products :: Gatorback® Belt Tensioning Systems
You do have to dl the catalog
Old Aug 17, 2009 | 08:40 PM
  #68 (permalink)
jturkel's Avatar
true true......that is good news, though then you still have an extra pulley when you get the pulley saver kit and you still ended up purchasing what is to be a $197 stud lol.
Old Aug 17, 2009 | 08:41 PM
  #69 (permalink)
32krazy!'s Avatar
d/l the catalog. all i found was the belt
Old Aug 17, 2009 | 08:43 PM
  #70 (permalink)
32krazy!'s Avatar
parts.com has the tensioner for 197 + shipping. cheapest i found so far but its the oem replacement. some have an inferior pulley and spring setup
jturkel im not sure but i dont believe the tensioner comes with the pulley. its listed separatley in the parts.com catalog. im under the impression the tensioner is 197$ by itself. pulley is extra like 20$
Old Aug 17, 2009 | 08:46 PM
  #71 (permalink)
jturkel's Avatar
well if you go this route, please to a DIY/write-up. it seems most of us are unfamiliar with removing the tensioner pulley on this car lol.
  #72 (permalink)
70GT6's Avatar
Applications
Note same tensioner is used on the SL55 and alot of other MBs
General Info
Old Aug 17, 2009 | 09:01 PM
  #73 (permalink)
MikeR's Avatar
The replacement of the tensioner is VERY easy. Two bolts. I did mine several months ago, and the new tensioner came with a new pulley installed. I got it through Tracy Bryan here on the forum.
Old Aug 17, 2009 | 09:05 PM
  #74 (permalink)
70GT6's Avatar
I have a question on this pulley saver kit - is the pulley assembly "dual" bearing?
Old Aug 17, 2009 | 09:07 PM
  #75 (permalink)
32krazy!'s Avatar
its not hard at all. remove belt. then the idler pulley. then the 2 bolts that hold the tensioner on. it comes off as a complete assy.
im going to check out the goodyear part at my local goodyear dealer tommorrow and see if its a viable part
Old Aug 17, 2009 | 09:12 PM
  #76 (permalink)
70GT6's Avatar
Also available at Autozone - if you have one close.
Old Aug 17, 2009 | 09:23 PM
  #77 (permalink)
32krazy!'s Avatar
tried all the big 3 parts stores. all they have is a dayco pulley which isnt the right type. still looking!
Old Aug 17, 2009 | 09:33 PM
  #78 (permalink)
70GT6's Avatar
Delete post - it is a special order.....
Old Aug 18, 2009 | 11:28 AM
  #79 (permalink)
tighed1's Avatar
your not using a e10 torx socket and grabbing the stud itself when you are releasing the tension? forgive me if im misunderstanding.
Nope. Not using the torx at all.
I tighten the "lock" nut harder against the pulley and then use the nut instead of the torx stud to release the belt tension.
Old Aug 18, 2009 | 11:38 AM
  #80 (permalink)
Bubba89's Avatar
I'm doing the same thing Tighed is to remove my belt and it works like a charm. I found that positioning the wrench so your pushing across to release the belt helps it from not loosening up, if you push down it tends to loosen every time. I used it to install the Tighed belt wrap kit coupled with my smaller supercharger pulley and 178 set up and it worked quite well so it should be able to work fine with the 185 install also.
Brandon
