Dyno Runs with 185mm and LET Tune
Old Oct 9, 2009 | 09:39 AM
testknight's Avatar
Default Dyno Runs with 185mm and LET Tune
Well two weeks after buying my C32 (59k miles) I took the 9 hour round trip to Eurocharged and back to have a 185mm pulley, intercooler pump and heat exchanger installed and then custom tuned. As they were tearing things down they noted I had a bad water pump so had to drop another cost of pump and 7 hrs of labor for that...its good its taken car of, but man that one hurt.
Anyway I was running stock intake with some used K&Ns they had in the shop (mine stockers didn't look so good.)
Unfortunately once I got there I found out they couldn't do a custom tune (I was pretty dispapointed by that), but they did try a number of saved tunes they had on file. Unfortuantely I was leaning out on top (bit erratic) and they did not have capability to tweak that for me....I am sure my numbers would be a bit better if they were able to.
Needless to say, I'm not real familiar with dyno dynamic numbers as I know they do report lower than dynojet (which is what I've always gone to). Reading here last night once I got home my numbers may be low...curious what you all think. Peak was 291.7 tourque is 330ish.
You guys think adding the SL55 Y splitter or perhaps full intake setup will help me much here? What do you all think this would read on a dynojet??? (I ask becasue thats a frame of reference I'm accustom too)
Old Oct 9, 2009 | 09:47 AM
testknight's Avatar
Default Re: Dyno Runs with 185mm and LET Tune
Oh...nice group of guys, pretty cool dudes. They seem to really enjoy what they do.
I know dynos don't tell the tale...unfortuantely its been nonstop heavy rain all the way home and this morning so no real butt dyno results....part throttle feels good, feels lights and 'sprintier' will share more on that once it dries up around here.
Old Oct 9, 2009 | 09:49 AM
goodgenes79's Avatar
With the supercharger attempting to suck in more air to compress with the biggest pulley out there, I would say that YES, an intake... a dual intake is necessary. I am thinking you are starving that poor motor of vital air, but how much it will show on a dyno is debatable. Assuming you see another 15 hp, that still seems low, but JMO. I will let the GURUs speak on behalf of experience.
waldig's Avatar
Talking Re: Dyno Runs with 185mm and LET Tune
Please tell me that the water pump did not cost 7 hours of additional labor. I have done the crossfire several times and its not even half that much time????????????
You need to consider a data logger to get the readings of the cars performance before you can evaluate the engine fully.
Question one is what is your fuel rail pressure??????Should recommend about 62PSIG for starts.
Woody
WEEKEND
WEEKEND
WEEKEND
WEEKEND
WEEKEND
WEEKEND
WEEKEND
Old Oct 9, 2009 | 09:52 AM
distantpulse's Avatar
What was the reason? Just not enough fuel to feed it??
testknight's Avatar
We did run it without an intake using a 3" (looked like 3") open tubi into S/C and it hit 305rwhp. Now that I would have been happy to see.
Old Oct 9, 2009 | 09:53 AM
testknight's Avatar
No I think they didn't have the equipment on site to tweak it. We could apply saved tunes, but no 'fine tuning'
Old Oct 9, 2009 | 10:32 AM
ZAHANMA's Avatar
This must mean that Tony did the tune and jerry had the laptop with him...Shame.
An intake would help a good bit.
18% is an average difference between dynodynamics and dynojet. you can also use this... POWER-TORQUE-RPM
as an idea... your 291 on a DD is ~342 on a DJ, but those numbers are guaranteed until you get on a DJ and really see what it puts down.
Old Oct 10, 2009 | 12:02 AM
ProjectMayhem's Avatar
I'd say you got another 25ish hp and 20ish torque hiding in there with a proper intake. The stock intake is way to restrictive even at stock boost levels put a dual 3 inch intake on there and get the tune adjusted and you have alot more power.
Old Oct 10, 2009 | 10:48 AM
dual intake would be a grt improvement...next time you head up to chicago, let me know...I am due for a run up there weather permitting. We are having a test and tune day on the 17th at US 41...you should run up and test against others....good luck with your HP...modding is fun..
Old Oct 10, 2009 | 12:01 PM
c32AMG-DTM's Avatar
DD's vary widely dyno-to-dyno; I've seen DD results that are less-than, approximately equal-to, and yes, occasionally greater-than DJ results for the same car.
As they (DD's) are typically lower, I've seen 'guesstimates' that proper % losses for our platform to compute output at the crank, DJ is 18% and DD is 20-22%. So even using the more-aggressive 22% factor, 291rw would be ~373 at the crank (up from 349), and likely would result in ~306 rw on a DJ.
I've never seen "18% is an average difference between dynodynamics and dynojet" - source please?
Old Oct 10, 2009 | 02:45 PM
32krazy!'s Avatar
dont have a source other than the tech that did my dyno baseline but he also said 18% driveline loss. mine was done on a mustang dyno
Old Oct 10, 2009 | 07:12 PM
c32AMG-DTM's Avatar
I think you misunderstood. I agree that an 18% driveline loss is very reasonable, and it's what I've heard from tech's as well (typically, 2wd platforms, 18-20% for an auto tranny, and 15% or so for a manual is what I've heard most frequently).
I've not seen before a claim that 18% is an "average" differential between rear-wheel DynoDynamics results and rear-wheel Dynojet results - not saying it isn't, but I just haven't seen it, so I asked to know the source where that number comes from is all.
I've edited the prior post so to avoid confusion of what I meant, I can see how it was misinterpreted.
Old Oct 12, 2009 | 01:22 PM
testknight's Avatar
Yep, love to mod my cars. This is why I chose the C32 over any of the R Series jags I was looking at...more potential (and more pleased each day I decided that although still have a fondness for some fo those jags).
Can't make the US41 meet this week...but Jerry has offered to help me out on this during a future event. IN the meantime, I'll keep an eye out for a dual intake option (not much there for us C32s so am thinking about a custom DIY intake of some sort as well as an SL55). Have some ideas on a DIY intake project....may post it in near future for feedback.
Where you from in Indiana?
Old Oct 12, 2009 | 04:41 PM
tom2112's Avatar
She can ride with me ;)
Let me get this straight, you drove 9 hours to Eurocharged to have your car modded and dyno tuned, and they didn't have the right equipment to do the work?!?!? Nice. I'd be more than a little upset about that.
Kodebuster
Nov 5, 2020 04:06 PM
xfireohio
Jul 20, 2020 12:03 AM
gblack32
Sep 7, 2016 08:27 PM
Zoodust
Aug 21, 2015 10:39 AM
Zoodust
Jul 16, 2015 06:17 PM
