Common Problem
Old Jun 5, 2010 | 03:48 PM
MyWifeSrt6's Avatar
Default Common Problem
Newbie from Little Rock AR. We traded in my wifes Altima for an Srt6 a few months ago. I was really disappointed that the supercharger turns off, and comes on, turns off, comes on... We thought this might be normal until I did some research on this site. We have already put the car up for sale locally because it is a real nuissance losing power in the middle of a race, then getting the thumbs up from the other driver when he flies past you cause you are topped out at 115mph. Does this sound like the typical IC pump? If so, where is a good "how to" write up on changing this out? I searched with no luck. Ive also tried looking for this pump on the car and didn't know where to start.
I have a Kennebell blown SS Silverado, but no intercooler. So this is a new one for me. Thanks, sorry for the long post.
Old Jun 5, 2010 | 05:17 PM
32krazy!'s Avatar
Default Re: Common Problem
pass side inner fenderwell door. open it and have a look. theres the pump.
pinch the lines and remove the clamps remove the elec. connector remove the pump. oem aftermarket cm30 pump your choice. rewire reinstall lines new clamps purge the system and enjoy!!
total cost at the dealer 700$ total cost for the diy around 175 with coolant added
Old Jun 5, 2010 | 05:44 PM
this is an easy install....and I wouldn't sell it until you feel the real power which you haven't done so far....probably why the other person sold it...lol
anyway, all those who flew by thinking they had a "kill" will look in amazement when you dust them off the road...and think....he was just letting me win....
Old Jun 5, 2010 | 06:04 PM
GDC-SRT's Avatar
This link should help!
https://www.crossfireforum.org/forum...placement.html
Old Jun 6, 2010 | 12:38 AM
cruzinquick's Avatar
Yes don't sell it, unless your Silverado is in the 11's, you'll want to keep it. These cars are pretty easy to work on, I've done all my mods myself and don't even own a code reader. If you use the right parts and companies you'll never throw a code with mods. Familiarize yourself with the plumbing and it will all come together. PM me if you need more help. The link above is right on the money.
Old Jun 6, 2010 | 01:16 AM
MyWifeSrt6's Avatar
Thanks for all the help! Its dark out now but I will look at it tomorrow. I will never let my wifes car be faster than the truck! Ha!
Old Jun 6, 2010 | 01:25 AM
BrianBrave's Avatar
<--- Huge Horsepower
Auto Performance Engineering - Johnson CM30P7-1
All the data and pricing as well
Its been a good low-cost and very reliable pump for me:
Old Jun 6, 2010 | 03:35 AM
tighed1's Avatar
More pics here How to Super Cooler - CrossfireForum.org Gallery
Old Jun 6, 2010 | 10:29 AM
MikeR's Avatar
Brian,
That is just mean to show him a pic of yours with the pump in the engine bay with all that bling.......
Old Jun 6, 2010 | 11:30 AM
ModlessG's Avatar
I just ordered the Johnson IC pump.I have had random power loss especially on hot days. For the price why not go ahead and change it out. The day I test drove the car it was cold almost spitting snow. The car was a rocket. It never ran that good again.
Old Jun 6, 2010 | 06:48 PM
MyWifeSrt6's Avatar
I will definately get the Johnson. I was reading some others going out after10000 miles with the ford pump. What are the symptoms of an IAT sensor going out? Thanks for the Pics! I cant ever get this kind of help on my forum!
Old Jun 6, 2010 | 08:28 PM
parawxman's Avatar
My car had the same problem with the supercharger switching on and off. The IC pump was NOT replaced. My car turned out to have a faulty sensor and has not had a problem since. I'll dig out the paperwork and find the part number of the sensor and post tomorrow, just in case it's not your pump.
Old Jun 6, 2010 | 09:35 PM
tunaglove's Avatar
You never know. I've got 72K on the original pump and it works fine. First see if your heat exchanger is plugged full of sand and junk and not cooling. You can remove the two plastic lower grills by using a screwdriver and releasing the plastic clips on each end. I used compressed air but a power wash would work also.
Old Jun 6, 2010 | 10:44 PM
Headlock's Avatar
The name of it is aux water pump
Old Jun 7, 2010 | 02:07 PM
Arizona John's Avatar
I have had similar problems with my SRT. The power loss was unpredictable, and when it went out I felt like I was on a bicycle...no power at all. Living here in Phoenix, the heat is certainly an aggravating factor. I just replaced my IC pump with a stock replacement....bought from Rob at Needswings. My car just turned 18K on the odometer, but sure enough it was the pump. Since I was doing this I took the opportunity to flush the entire cooling system and replacing the factory coolant with Zerex G05. I also added one bottle (a pint I believe) of Water Wetter, obtained from the local Checker Auto for about $8.00. I also installed one of Needswings isolation kits, which is a 10 minute modification. Its been 3 weeks now, with daytime high temps way above 100 degrees. No power losses at all, and the car is running great!!
For the record I too was concerned that it was a bad IAT sensor, but it appears I was wrong. It is amazing what just a new pump will do to fix
the problems. I didn't pick the Johnson pump since I was worried that it's higher flow rate might increase internal pressure and cause the actual intercooler under teh SC to spring a leak...probably too cautious on my part.
Good luck. I would suggest you try these mods first (total cost was under $225 including new coolant and Water Wetter) before selling a GREAT car.
It goes like stink, and is a blast to drive.
John
Old Jun 7, 2010 | 02:30 PM
rcompart's Avatar
Actually it is the "Charge Air Cooler Circulation Pump".
Old Jun 8, 2010 | 12:05 AM
MyWifeSrt6's Avatar
We have about 50,xxx miles on the car and I'm sure its never been changed out. I will try the pump first. I found the little door and the pump. Hopefully that will do it.
Is it possible that the gas mileage would drop when the SC is not working?
Old Jun 8, 2010 | 09:15 PM
ModlessG's Avatar
My gas mileage has been good for what the car is. The low was 19 all city traffic. The high 23 mostly highway. what are you getting?
tcar32909
Aug 1, 2024 02:41 PM
nataliefs
Oct 5, 2015 01:03 PM
cdcrone123
Sep 20, 2015 10:02 PM
tritongreen
Sep 18, 2015 07:32 AM
skeet370
29
Sep 18, 2015 05:53 AM
