Transmission Fluid
Hey guys not sure if you know this but the trannys we have, have a protective overflow drain. If you do end up putting to much fluid in the tranny during use and when it becomes hot it will dump the excess fluid.
Can’t in good conscience recommend establishing proper ATF level via “dump[ing] the excess fluid.”
I understand that I mean by no means am i going to just go dump 10 quarts of fluid and say the tranny will dump it out. Just saying they dont have to be spot on. BTW thanks for that chart I need to check my fluid and I couldn't find that chart.
Originally Posted by waldig
WOW< it is so good to see that Splinter is still among us. Great to see ya, enjoy, Woody
I had bought ATF 4 for Mopars tranny and had to drain and refill with whatever MB dealership had for ther latest specs. Its all backward compatible and the latest has better additives, and its cheaper at MB than at Chrysler/Dodge.
I'm a little late to the discussion, but here is where I bought my transmission fluid and filter kit online, plus the adapter plug housing I needed to fix my leak.
Transmission Fluid-OEM Fuchs 4 Liters 2002-2010
Because my AT is not very smooth i decided to change the atf oil and did a little research.
Here is the result:
The OEM atf supporter for Mercedes-Benz is FUCHS oils.
The recommended FUCHS atf oil for the 722.6 XF transmission is FUCHS TITAN ATF 4134
There is also a Website where you can search FUCHS lubricants for your car:
FUCHS Lubricant Advise
There is also an interesting way to change the atf oil. It was invented by Tim Eckart.
Because the 722.6 transmission has no drain plug for the torque converter, he is spilling the complete converter with a pump system, uses a cleaning fluid to spill out all impurities and fills in new atf oil.
He's also using FUCHS TITAN oils. Clients are very happy with the results.
Website Tim Eckart (german language):
Englisch
Youtube Video (german language, but i think you'll understand how it works)
YouTube - ‪AMG C32 Vorlaufspülung www.Automatikoelwechselsystem.de.wmv‬‏
Here is the result:
Englisch
RE: SRT-6 Transmission Fluid. Old Thread, new question. I contacted Mobil about their recommended trans fluid. Response: Mobil ATF-4
Mobil ATF+4
Experts, Yes or No
Mobil ATF+4
Experts, Yes or No
Mobil ATF+4
Experts, Yes or No
Mobil ATF+4
Experts, Yes or No
NeedsWings Performance Products. 7226 Transmission Service kit
I'm a firm believer in supporting our Crossfire Vendors as they provide a valuable support service to our marque. If the price difference between one of our preferred vendors & another source is 10-15%, I'll buy from our preferred vendor. But in this case, there are considerably less costly (35%) alternatives to the kit provided by Needswings (sorry Rob). Now, the kits aren't exactly the same as Rob provides a couple of additional parts, but the kit listed on Amazon is worth looking at.
2001-20014 SLK320 5-Speed AutoStick Transmission Service Kit
And Ravenol is listed as a certified (tested & approved) transmission fluid meeting M-B's 236.10 specification. Interesting that Ravenol is shown on the label as a Semi-Synthetic fluid.
jimf
Oct 10, 2015 10:22 AM
