Jack Pad Replacement
Old Sep 13, 2012 | 01:05 AM
AlbertFattal's Avatar
Default Jack Pad Replacement
Recently ran over a bump that riped off my Front Drivers Side Jack Lift Point Pad, I was pretty worried, I think I also messed up my alignment!
I just sent in a request to my dealer for the replacement pad - anybody have other recommendations as to where I can find one for a moderate price? I am seeing them int he $50 range...
Old Sep 18, 2012 | 08:08 PM
Default Re: Jack Pad Replacement
OUCH $55-$85 to repalce a jack pad? What the heck is going on...
Anybody know of a replacement for a more reasonable cost?
Old Sep 18, 2012 | 08:18 PM
bluecoupe's Avatar
wonder if these will work?
mercedes slk jack pad | eBay
Old Sep 19, 2012 | 01:49 AM
Try MrMopar.
Old Sep 25, 2012 | 07:44 PM
Looks like I am just going to buy the stock Mercedes Part for the SLK and do a little bit of trimming to get this to fit. Beats spending 3x more for minimal differences.
Old Sep 25, 2012 | 08:03 PM
bluecoupe's Avatar
Please post and let us know how it works out for you.
Old Sep 28, 2012 | 11:18 PM
GOt the jack pad today, it was the $15 Mercedes jack pad part number 2039970186, infact here is the direct eBay link I bought it off of: Genuine Mercedes Benz Jack lift Pad rubber SLK280 SLK350 C230 C350 #2039970186 | eBay
While it was not an EXACT match, one can trim it to fit well, but for me, I just put it on the car without trimming and it pretty much went in and did the job. Totally worth saving that extra $50 for something with just a few corner differences.
So yes, it does work and function well, but it is also slightly different. Totally worth it.
Old Sep 29, 2012 | 01:36 AM
Wedge's Avatar
Thanks AF,
Just bought one through the ebay link you posted
Old Sep 29, 2012 | 08:14 AM
bluecoupe's Avatar
Many thanks, that's good to know. I think I'll pick up a spare set!
Old Sep 29, 2012 | 03:49 PM
Just a question, you say that it can be trimmed to fit well, but it fits. How can that be true? If it needs to be trimmed it means will not fit.
If it fits how can you trim it to make it fit?
Old Sep 29, 2012 | 04:09 PM
Someone had to mess with your mind today......I hope he never answers...lol..... Just buy 4 of them, and they will all look alike....
Old Sep 29, 2012 | 05:33 PM
bluecoupe's Avatar
LOL, just Dave being Dave!
Old Sep 29, 2012 | 06:10 PM
He says corner differences, does it not quite fit n the corners? If so the weight of the car may damage the rocker panel when the car is lifted using the pad.The pad directs the body weight onto the frame and not the rocker panel which is just sandwiched between. If it does not sit against the flat area of the rocker panel then damage will be done. A cracked rocker panel will cost more than the savings on the pad if it does not fit correctly.
Inquiring minds want to know.
Old Sep 29, 2012 | 07:48 PM
That certainly is true Dave....we need photos....
Old Sep 29, 2012 | 07:58 PM
There is a method behind my questions at times, I try not to indicate the exact point of interest, so that I do not put words into someones mouth.
Nothing is gained by letting on where the problem I see may lie, if you see my point.
Old Sep 29, 2012 | 08:01 PM
Mrmiata's Avatar
Figuring out when you have method .. and when you just have boredom is the fun part..
PNA
Nov 12, 2020 04:44 PM
Kodebuster
Nov 5, 2020 04:06 PM
Adrian_X
Apr 8, 2020 02:36 PM
Roty135
17
Oct 11, 2018 10:11 AM
Romio
Jul 24, 2015 07:04 AM
