gas leak
Old Oct 29, 2012 | 06:07 PM
Daddy's Avatar
Default gas leak
So, I was on my way home tonight and stopped to check the tire pressure when I smelled gas. I did a quick check under the passenger rear side and I could see three drops of gas dripping from underneath the car. I know it was gasoline because I used my hand to wipe it off. So my question is: are there any known troubles with gas leaks with this car? I will have to wait until I can have simone drive me to where I can use a lift to get under her and check things out. Just looking for some common issues with has leaks right now.
Old Oct 29, 2012 | 06:37 PM
vinnys's Avatar
Default Re: gas leak
Fuel pump. Just ordered mine. Same car only a coupe. Same thing, smell of gas and a few drops. Pulled cover and pump was leaking. Got a Bosch from Amazon for $199.00. Looks like an easy fix. Good luck!
Old Oct 29, 2012 | 10:21 PM
Daddy's Avatar
If this is the issue now might be the right time to upgrade the fuel pump. I need to do some reading up on what pump where to buy etc
Old Oct 30, 2012 | 08:57 AM
Semlinger's Avatar
Fuel filter is there . Pump is in the tank. You need a long 3/8 extension to remove the top nut on the cover stud. The filter has a built in pressure regulator. Cost maybe $40.00.
Old Oct 30, 2012 | 09:25 AM
Mrmiata's Avatar
If your working on an 07 Tahoe I can vouche your correct.. crossfire though you might want to look at the panel in the fender well in the right rear wheel location.
Old Oct 30, 2012 | 10:23 AM
I know the filter is there, but I thought the pump was in the tank?
Old Oct 30, 2012 | 10:32 AM
Mrmiata's Avatar
https://www.crossfireforum.org/forum/575202-post3.html
https://www.crossfireforum.org/forum/521223-post2.html
I'm convinced...
Old Oct 30, 2012 | 11:38 AM
tunaglove's Avatar
The pump and filter are under a plastic cover in the right rear. 3 10mm nuts hold the cover on. The pump is inline not in the tank.
JesseJamessrt6's Avatar
fuel pump is not in the tank, it is right next to the fuel filter. The plastic shield is very easy to remove to inspect.
Old Oct 30, 2012 | 12:01 PM
Mrmiata's Avatar
And I was more than happy to point this out after having a shop lower the tank and replace my wife's Tahoe pump with the built in filter.. and $750 at the Chevy dealer (walk out the door with it in a box price!).
(yes I said shop.. floor jack and 120 lbs of fuel didn't seem promising..).
Old Oct 30, 2012 | 12:13 PM
tunaglove's Avatar
Gotcha......
I usally have to read your posts 3 or 4 times to figure out what the hell you are talking about. LOL!
Old Oct 30, 2012 | 12:19 PM
Mrmiata's Avatar
Gotcha......
Good to know that extended reading program is paying off! LOL.
Old Oct 30, 2012 | 03:52 PM
I stand corrected.
Old Oct 30, 2012 | 04:11 PM
Mrmiata's Avatar
I stand corrected.
I get bored during the wife's re-runs and do lotsa reading on here.. LOL.
Old Oct 30, 2012 | 04:55 PM
i have experience; a face full of supreme when I pulled the fuel line off the stubborn fuel fitler to replace it.
Old Oct 30, 2012 | 09:22 PM
Daddy's Avatar
Been doing some reading on cff on different ways to. Correct the lean issues some are having with modifications. So is the consensus to use the sl55 pump or will the walbro pump work just as well? What is this bosch pump? Better worse or same?
Old Oct 31, 2012 | 08:09 AM
Gary, there are literally hundreds of posts on these fuel pumps and lean issues, many have tried many different ways of conquering the problem, all are documented on the site. I would either do some searching and reading, or post in a fuel pump thread in the SRT section that is already started....
minimayhem
16
Aug 23, 2016 07:47 AM
RacerXofFL
Sep 15, 2015 05:00 PM
BEATv1
Sep 10, 2015 12:58 PM
MickeyNasty
Sep 6, 2015 08:29 PM
williammt
Sep 6, 2015 11:23 AM
