lowering battery voltage, engine startup problem
Old Sep 22, 2013 | 04:33 PM
blueeyes147's Avatar
Default lowering battery voltage, engine startup problem
I use my crossfire SRT6 only on weekends, and I happen to power the motor turns bad as if the car had a carburetor incorrect after several investigations found that the mechanic has just lost a bit of the battery charge to verify this problem, I put a battery faster, but nothing, created a button which disconnects the battery contacts when the car is stationary, but nothing I bought a maintenance charger and seemed to have solved the problem but today there was still the problem , then to get it started properly I have to use a starter more powerful. has anyone had the same problem? it takes a battery in particular? please consigliatemi are one of the few Italian with SRT6
Old Sep 22, 2013 | 04:53 PM
Default Re: lowering battery voltage, engine startup problem
What is the age of the battery? These cars are very fussy about old batteries.
Also, check the condition of the battery cables, check battery ground cable at both ends - clean and tight?
Old Sep 23, 2013 | 02:05 AM
the battery has been replaced recently because of this problem, install a more powerful and were also cleaned and replaced the cables with thicker cables after you have cleaned everything, for some times went well, but then the problem came back, I think because the car has very little
Old Sep 23, 2013 | 03:59 AM
Now i have this battery
RTC4.2 BATTERIA OPTIMA ROSSA RED TOP CHRYSLER - DODGE VOYAGER REDTOP 50 AH 815A | eBay
And this battery charge
MANTENITORE DI CARICA UNIBAT UNICHARGER IMPERMEABILE MOTO AUTO SCOOTER ATV QUAD | eBay
Old Sep 23, 2013 | 04:00 AM
Old Sep 23, 2013 | 07:08 PM
cudaman's Avatar
Check also the RCM (relay control module) if the battery doesn't solver your issue.
RCM solder problem threads:
https://www.crossfireforum.org/forum...ine-light.html
Larry may be right.
The relay for the air pump is in the RCM (relay control module) and it is known to have suspect soldier joints.
If yer handy with a solder iron check out this LINK.
https://www.crossfireforum.org/forum...-no-start.html
This post is in response to the MANY occurrences of the "Mystery No Start" issue. Symptoms being car will die and/or will not restart but may restart after waiting for a while. Also, when attempting to start the engine all electronics work but the engine will not crank.
Hundreds have been spent "repairing" this problem by buying a new Relay Control Module (RCM) and paying for diagnostics, removal and installation.
Well I'm here to help save you some time, $$$ and aggravation cuz YOU will do the repair yer self!
This repair will require that you are able to properly operate a soldering iron. Beyond that it’s pretty easy.
Let’s get started (get it?)!
(great pictures in this lin
k)
Old Sep 23, 2013 | 07:09 PM
cudaman's Avatar
seems to have double-posted. sorry.
Old Sep 24, 2013 | 02:17 AM
this can also cause my problem? that is, lower the voltage of the battery even when the battery is disconnected via a special button? and then create a boot crash of my SRT6?
Old Sep 24, 2013 | 02:20 AM
my SRT6 starts, but in an unusual way seems like it scarburata sobs and also makes smoke darker, then if the charge to the battery with a starter start properly
Old Dec 31, 2013 | 10:22 AM
This is my problem
Old Dec 31, 2013 | 08:16 PM
aplusbrian's Avatar
There may be other on here with better knowledge of your problem but it sounds like your cam shaft of crank shaft positioning sensor is not working properly and causing the ignition timing to be off.
How does it run when it warms up? does it keep back fireing?
Old Jan 1, 2014 | 06:09 AM
does not get better when it warms up I have to use a starter connected to the battery and after several attempts part correctly then it's okay if I continue to use the car as it remains stationary for a few days the problem reoccurs
KDW4Him
18
Sep 1, 2021 05:47 PM
Hoppy
Dec 7, 2018 07:36 AM
spoiler
Sep 2, 2015 08:56 PM
Mark McKay
Jul 17, 2015 01:18 PM
2004_
Jul 13, 2015 02:04 PM
