Newbie w/broken motor mount
Old Nov 7, 2013 | 11:37 PM
jdlong357's Avatar
Default Newbie w/broken motor mount
So, just bought my first Crossfire, the SRT6 and just broke a motor mount. Just curious if this is a typical issue others have encountered. I work in an area that has some pretty crummy roads, but I don't think that was the because I got pretty good at playing pothole dodging
Old Nov 8, 2013 | 09:21 AM
NeedsWings's Avatar
Default Re: Newbie w/broken motor mount
you will want to replace both motor mounts and the trans mount together as they are surely weakened with a motor mount broken. I have not seen one physically break yet, post pictures, usually they just leak out and go weak.
Old Nov 10, 2013 | 12:44 PM
jdlong357's Avatar
The dealership will be replacing my motor mounts tomorrow, then I'm doing the tranny mount next weekend. As soon as I get it back, I'll post those pics. My coworker helped confirm the left one broke. Jacked it up and there's almost two inches of gap between the motor mount and motor when you apply any usable torque.
Old Nov 10, 2013 | 08:15 PM
dskul1's Avatar
I had my SRT for about 2k miles and my left mount broke. I don't know if it motor mounts are a weak spot or not. I replaced both mounts with ones I purchased on line. They were a lot cheaper ($115.69+shipping for both)than most of the other mounts I looked at, but were German made. Just had my mechanic put them on for $50.00. After I had already put them on, some people said that the ones I put on were not very well made in their opinion. I have had them for about 1.5 years and 6K miles and no problems. I drive on roads that are very twisty here in E. Tennessee, but not very many pot holes, etc. I drive quickly, but I am not hard on the car. This is the E-bay store I bought them at: STEERING SUSPENSION, BMW items in Deutsche Parts USA store on eBay! I never have had to replace the transmission mount. So far...... Good luck w/you SRT! I love mine!
Old Nov 10, 2013 | 09:39 PM
+fireamx's Avatar
Some people have used braided steel cable, or a chain to hold their motors down. But I think it's mostly for drag racing. But if it works under extreme use, it should be a little extra insurance for everyday use. Especially if the factory motor mounts are known to fail.
Old Nov 11, 2013 | 02:04 PM
Billy22Bob's Avatar
very timely thread....
I've noticed my gear shift moving around a bit more under WOT the last week.
Wondering if its always been like that? and I'm just noticing it now or....I've blown a mount because I've been pretending to be Sebastian Vettel too much..;>)
Be interested to know if your gear shift movement has abated since the new mounts went in?
PS - one always goes more than the other because when the engine twists - one is under tension and the other is under compression.
Old Nov 12, 2013 | 07:54 AM
jdlong357's Avatar
Default
Yeah, the left one likes to break more. I'm finding more info on this as I await my car back. You can try two things, but I don't recommend the second unless you're really not sure. First, try driving slower, keep your hand on the shifter and see if it stops moving. For the second, in a safe place, gently power brake it (yes I know how it sounds) until it either slips the tire, or if the left mount is broken, it will lurch up and forward slightly, then when you let off it will kind of thunk back into place. Like I said, not my favorite testing method but it works
Old Nov 12, 2013 | 12:46 PM
dskul1's Avatar
When my left motor mount broke, I could feel it in the shifter moving under acceleration and the engine would move enough to hit the hood of the car. I looked at the hood and could see where the top of the motor was hitting the underside of the hood. Not very hard to determine the problem really. Just replace the mounts and your good to go.
Old Nov 13, 2013 | 08:53 PM
JesseJamessrt6's Avatar
The driver side is always the one that breaks first, it isn't design to resist lifting over time, it is better at compression resistance. I replaced mine with OEM Mercedes from Rob and haven't had a problem since.
A steel cable is good to use until the new one comes in. If you take the cable off after it is replaced you will know the next time it breaks. I have an exhaust leak that I can start to hear now though.
We could all use a top SC mounted torque link or a third OEM mount. It would need to be on the driver side somewhere with the bottom of the OEM mount bracket attached to the engine and the top of the OEM mount bracket attached to the wheel well/braced to frame. This would compress the mount like the passenger side instead of trying to lift/stretch it.
Old Nov 14, 2013 | 12:11 AM
jdlong357's Avatar
Default
My apologies folks, I bought mine at a Ford dealership. When they fixed it, they took it to Mercedes for repairs. They did not forward my request for the broken parts, therefore, no pics that were promised. On the upside, I got OEM mounts on both sides replaced, along with a Mercedes relay that was on its way out for the Secondary Air Intake Sensor. If you were to go with a chain or cable permanently, you may as well just install the cheaper, solid polyurethane mounts. My thoughts were that if the manufacturer used a hydraulic mount, there may have been concerns of frame twist over time. I would research more before trying this permanently. I do agree that a chain or cable is a good way to get by without causing further strain o. The right and tranny mounts until repairs are done. I'm going on the Tucson GTG Saturday, so in doing a new tranny mount the following weekend. Good luck on your mounts, hope for a speedy recovery.
Old Nov 14, 2013 | 11:49 AM
Billy22Bob's Avatar
I looked at a friend of mine's Nissan GTR and he had a torque lin kinstalled from the Right hand side (RHS) block to the RHS suspension tower. My only concern with this is the engineering around the tower and if it will induce a twist which could upset handling.
franklindm
Mar 14, 2020 12:23 PM
steps
Apr 26, 2016 06:21 PM
Nov 11, 2015 05:22 AM
Billy22Bob
Oct 1, 2015 05:34 AM
Oct 1, 2015 01:42 AM
