Interior lights won't work when doors open
Old Jan 12, 2015 | 11:17 PM
Shelbygto2's Avatar
Default Interior lights won't work when doors open
If I have the buttom pushed or not they dont work upon door opening or unlocking of doors. They work when I push the button to turn them on but not when I open doors.
Old Jan 13, 2015 | 12:17 AM
rmcdaniel12's Avatar
Default Re: Interior lights wont work when doors open
Not to be try to be Captain Obvious, but do u have the black slide (in between driver side light and passenger side light) slid over to the option to keep them off upon opening the doors! This while still allow u to manually turn them on, but they won't come on when opening doors or locking/unlocking doors.
Old Jan 14, 2015 | 07:32 PM
maxcichon's Avatar
OFF/DOORS/ON
For the 3 positions.
Old Jan 14, 2015 | 09:09 PM
I have had the same problem since Christmas. But it ain't the switch.
IT IS FRACKIN' COLD OUTSIDE.
The button sticks.
Old Jan 14, 2015 | 10:27 PM
OFF/DOORS/ON
Two positions I think, Auto On and Off.
Slide toward driver is Off.
Slide away from driver is Auto On.
Old Jan 15, 2015 | 08:28 AM
^^^ What Dave said : ( Max is from planet X, there they have 3 positions )
The button with the rising sun symbol is the manual on/off.
Old Jan 15, 2015 | 12:15 PM
maxcichon's Avatar
Everyone can make a mistake, guys. That was my Accord.
SOOOOOOORY. Sheesh
Old Jan 15, 2015 | 02:51 PM
Mrmiata's Avatar
SOOOOOOORY. Sheesh
Tough crowd huh Max! LOL.
Old Jan 16, 2015 | 08:24 AM
maxcichon's Avatar
I guess so.
Old Mar 25, 2015 | 11:17 AM
Cerda-fied's Avatar
Default Re: Interior lights won't work when doors open
While working on my central locking unit in the trunk that got water in it by a leak it affected my interior lights. If unplugged no lights would come on for doors but still worked in manual and locks acted up. Check for water under foam in passenger side trunk.
Old Mar 26, 2015 | 05:49 AM
Billy22Bob's Avatar
Yes - this is a common problem with the Mercedes R170 models...SLK230/320 and 32.
I replaced the central locking pump in my SLK230 after months of trying to fix the old one.
Couldn't find one for <$500 though...pretty exxie.
Not sure its much of a problem with the SRT's though. For the mercs, they eventually lengthened the yellow tubes and turned the unit upside down so water didn't accumulate in the bottom where the circuit board is.
some pics here.
Not to say it is the problem you have - but it is very common and worth checking. Its not a major job to check.
Old Mar 26, 2015 | 09:11 AM
some pics here.
Or the unit was placed in a sturdy plastic bag, with no holes in it and not sealed up.
Old Mar 26, 2015 | 08:40 PM
Billy22Bob's Avatar
hhmmm...I don't recall the sealed bag was the end solution....'cause the pump's gotta pump air to (and from) the latches...the pump needs to suck/push....hence I think the bag idea led to condensation/sweating...which was one water source..
..the other was water used to run down the filler cap yellow pneumatic hose onto/into the unit and..
.. if you didn't/don't keep your rear gutter drains clear (SLKxxx), water may enter the trunk/boot...run down to the trunk floor and then sit and sweat+cause more condensation around the foam box hosing the PSE (the pump unit we are talking about)....etc...etc...
after thought....I just re-read your "not sealed up comment" I get you...
Old Mar 29, 2015 | 12:23 AM
Huh? I have no idea what your talking about (he he he he)
amatxcrossfire
Aug 15, 2015 01:28 PM
carmax
Jun 18, 2015 01:30 PM
crossfiretech
Sep 6, 2003 09:08 PM
X-fired
Aug 28, 2003 11:34 AM
mouserider
Jul 26, 2003 11:47 PM
