Supercharger is not working at all..
Old Jul 13, 2016 | 06:52 PM
Zoodust's Avatar
Default Supercharger is not working at all..
Hey everyone, I'm currently having a huge issue with my car. I've been in contact with Needswings and many other members(all have been great for the help and we are still working on it) But, i'm wanting to address this issue as well on the fourms for the time being since the issue is still happening. The SC would randomly cut in and out starting 5 weeks ago and as of 2 weeks ago the SC would not engage at all, even at cold startup. Last night and today same issue, no boost at all is being made. I tried the IC pump on at all time mod along with burping the IC system and had no bubbles in the system. Today I went to floor the car and the BAS ESP light came on and then turned off along with a lumpy idle for a few moments. Afterwards, i filled car with new gas, did a throttle reset, and even disconnected and reconnected the SC clutch sensor. I'm throwing p0135, p0155, p0410, p0412 codes. I've recently installed new 02 sensors but the codes are still there.. any thoughts?
Thanks,
Mark
Old Jul 14, 2016 | 09:32 AM
tunaglove's Avatar
Default Re: Supercharger is not working at all..
Po135 and po155 are the front oxygen sensors heater problem. Is it possible you swapped the plugs when replacing them? Po410 and po412 are for the air pump. Is it possible you have the vacuum line going from the back if the charger to the SAI valves disconnected? Does the pump run when you do a cold start?
Old Jul 14, 2016 | 10:31 AM
Zoodust's Avatar
How do i know if the air pump is working ? I assume it is not since the code is being thrown
Old Jul 14, 2016 | 07:11 PM
NeedsWings's Avatar
https://www.crossfireforum.org/forum...t-working.html
https://www.crossfireforum.org/forum...clutch-sc.html
Old Jul 14, 2016 | 08:55 PM
Zoodust's Avatar
Rob, i have tried and already messaged FTcrossfire from the first link you posted.. his problem was that his SC clutch wires were shorting out. I tested mine today as he messaged me to do so and it was making all the power
Old Jul 28, 2016 | 11:58 AM
robbie's Avatar
Super charger pig tail
Old Jul 28, 2016 | 12:56 PM
Zoodust's Avatar
What is that ?
davidf30
Feb 19, 2020 10:00 PM
Sussudio
Jan 31, 2016 10:32 PM
skeet370
Jan 16, 2016 11:19 AM
Alfred107
Jan 6, 2016 10:19 AM
AZ Outlaws
Feb 19, 2004 04:12 PM
