Engine cover rubbing on SC pulley
Old Oct 15, 2018 | 12:17 PM
dizzyspots's Avatar
Default Engine cover rubbing on SC pulley
Getting the new 6 tidied up a bit...
oil and filter changed,
front calipers painted (thanks Chrystal!)
noticed that the engine cover has rub marks from the hood insulation
FYI the original flat tire kit is still in its original wrappings..never been touched
the sc pulley looks like its been rubbing on the engine cover...thin strips of what looks like plastic around its complete circumference at the rear edge of the pulley.
new rear rubber scheduled for this morning...Discount Tire had to order the Barum Bravius tires (made by Continental and at $81 for 255/40-20 Ill give it a shot to get the 6 on the road and can switch or upgrade later
PS how do you get the plywood, foam inserts out of the truck recess to check the unlocking pump for water intrusion??
Old Oct 15, 2018 | 02:19 PM
magredvet's Avatar
Default Re: Engine cover rubbing on SC pulley
The trunk side panels need to be removed to get the foam inserts out. As far as the engine cover is concerned, I'd just remove it, and get a supercharger plaque
Old Oct 15, 2018 | 04:03 PM
My hood liner made marks on my NA engine cover at the front, I used contact glue which I applied through a slit in the liner, put it in onto the metal, pushed the two together, separated them till they were tacky and pushed them together again.
It may seem a tacky way of doing it but it held the liner up and away from the cover and all was good again.
coryforman
Apr 7, 2017 08:19 AM
2005-SoCalXfire
Apr 9, 2006 06:02 PM
MAYAman
Sep 22, 2005 05:02 PM
brittt1
Apr 28, 2005 03:02 PM
thrilled
Mar 12, 2004 03:49 PM
