Squires rear turbo system.
I spoke to Wayne at LET and he said he had a solution to the MAF/Speed density issue.
Originally Posted by ShinobiOfLegends
whats he gunna do? use a vane air flow meter and use it along with the MAP to create his own "MAF" sensor??
I should have listened better. I was only concerned with the fact that he could tune it to run great. He mentioned the issue and what he done to make it all work.
Originally Posted by psuperti
I'm out of this STS project. I found a Top Secret never done before custom mod, it puts a base crossfire at 360 HP
. I'm half way done and time for delivery is July!
I almost forgot to report that I'm finished! I'm running two shots of nitrous. I only had 75hp, now 130hp. I added a WOT swich and a 2nd fuel pump. I'm also running a city ECU Tune for the city and one for Racing (20hp). I'm very happy with it, sorry its not a turbo or supercharger. I'm going to the TMS laps for charity and disclose my mod there.
Originally Posted by MI1XFIRE
Sweet.......are you running both tunes on the same ECU?
So I am putting funds together for this now that i have the intake and TB and such. I'm about to sell my Greddy E-manage Blue to put more funding in the RMT account, UNLESS you guys think I'll need it for the build. I have looked into it a lot and haven't read that i will need a piggy back system... Anyone know things i don't?
Originally Posted by ZAHANMA
Well it's been proven that you don't need a piggy back for a turbo setup on these cars. Eurocharged/LET has a turbo SRT6 at over 500rwhp. So I would go with no, you don't need a piggyback for your ECU...unless there is something about a rear setup that would make it any different...
IF fine tuning is still needed Wyne form LET/Eurocharged would be able to make adjustments. Fuel pump and injectors form an SRT might be a good idea as well.
Just as a point of reference, if I remember correctly Jerry and Tony were responsible for the tuning on the turbo. I would go to them for any of my tunes...but everyone has there tuner preference...even within a company
Wayne does mostly mercedes work and Jerry does most of the Crossfire work if I remember what they told me. I have been talking to Wayne becuase of the nature of my V8 conversion which is a MB CL500 engine and Waynes experience with that engine and STAR DAS developer mode which probably will also be needed if someone wanted to program a SLK32/SRT6 ECU to a n/a Crossfire.
Like I said everyone has preferences...
Wait a sec, you got my head all wrapped up like a pretzel.. lol
So i don't need it cause we MAY be able to take a SRT ECU and use it on my N/A? Isn't getting it unlocked to be used on a different VIN going to be pretty difficult? I like the idea since it all stays somewhat "stock" but how do i get all that done??
If you have seen any of the recent tunes done by Eurocharged/LET on the V8 and bigger engines...its all Jerry. Jerry picked up 60rwhp and 170rwtq on a tune alone (everything else stock) on a S600 V12TT.
Now let's get back to figuring out how to turbo the n/a.
Then you would be working off of base maps designed for boost and the tuning process would be a lot simpler (in theory).
If a V8 ECU can be programed to a different car, which is what Kanzus did when he dropped a AMG 55 Kompressor engine into a C240 then using the same approach should be able to be used to adapt the SRT ECU to the n/a Crossfire and may even be easier. As soon as I have my V8 running, I intend to add forced induction just as KAnzus did and i will use the 55 Kompressor ECU to do so.
