Hood Liner
Old Sep 26, 2010 | 03:16 AM
HellsAngel91's Avatar
Default Re: Hood Liner
My Base doesn't have one, nor needs one, adds too much weight (the xfi logo one looks sick though!)
Old Sep 26, 2010 | 10:17 AM
wow, I think I might go out and lose a couple of hood liners this morning....been thinking about it for sometime now, just wasn't sure about the heat/paint...but, if what I am reading is correct, it won't make any difference, and the hood would look better for shows...thanks...
Old Sep 26, 2010 | 05:14 PM
GenoTex's Avatar
I took my hood to the local 4X4 Truck Shop and had the hot melt Line-X Truck Bed Liner sprayed underneath. Guaranteed for life. Over a year later and still looking So Good! Squirrel Crusher
$$$ ??? If you remember...
Old Oct 26, 2010 | 08:16 PM
KrzyFast's Avatar
If you are worried about heat, what about that new product LizardSkin that I see advertised on "Two Guys Garage" on Sundays? It is supposed to be a good spray on heat insulator.
Anyone tried it? It might be a good substitute for the underside of the hood.
Old Oct 28, 2010 | 08:57 PM
Infinite's Avatar
the mat does nothing for insulation.
were there to be an underhood fire the purpose of the mat is to fall off of its plastic mounts and smother the fire.
Old Oct 28, 2010 | 10:20 PM
The mat is already touching the engine cover and is not going to smother any fire, it would also have to fall out of the metal clips. Sitting on the engine the mat is not going to fall out of those clips
These things muffle sound and collect dust and thats about it.
Originally Posted by infinite
"Chipped vertebrae in my neck, concussion, amnesia, whiplash"
You are heavily sedated I think.
Old Nov 7, 2010 | 11:14 AM
zip439's Avatar
Was at the Benz site this morning and found some good info on hood liners [URL="http://www.benzworld.org/forums/r129-sl-class/1325955-bonnet-engine-hood-pad-r-r.html[/URL]
If Mercedes glues liners to their hoods (see pictures at link) on some other models, seems it would be OK for us to do the same. My OEM liner has shrunk, and I like to do a job just once, so why go back with another that will shrink in a couple years? Some of these guys left the hood on the car, then rolled on DAP contact cement vice a spray on adhesive.
I also believe the liner insulates the hood/engine; keeping the engine compartment cooler in the summer for those of us in the deep south, and keeps it warmer in the winter. Without a liner come a thundershower, and you may have steam coming off your hood. It helps insulate noise as well.
just my two cents worth, take it for what its worth, no arguments from me
Old Nov 7, 2010 | 08:02 PM
Larry Hitze's Avatar
Mine didn't have a liner when I purchased it three years ago, possible removed when it had bodywork done. I have not noticed and effects good or bad from not having it. To tell the truth I never gave it much thought until I went to some events and saw some other Crossfires with them on.
Da55id
16
May 10, 2016 10:37 PM
Charlesl
Sep 30, 2015 10:46 PM
mobilefitt
Sep 24, 2015 01:04 PM
csteve0355
Sep 23, 2015 05:57 PM
waldig
Sep 17, 2015 10:35 AM
