help transmission leak maybe?
so hears the problem i took my car up on a lift after i noticed a small oil stain (quarter sized) on my drive way it looks like there is a small leak coming from the front seals of my transmission. i understand to fix that it would most likley be really expensive (the ONLY down side of the MB motor) but i cant find the trnsmission dipstick?? or resivior? so guys should i just add a little fluid everyone once in a while or....?
Did mine just a few weeks ago. Would be a very easy job if you have a hoist. PITA if your laying on your garage floor with the car as high as you can get and your gut is jammed up against the underbody. Obviously I don't have a hoist.
Dave
I lifted mine on the passenger side only and as high as my jack would extend...approx 18 inches. Less fluid will drain out when lifted on the passenger side only. ALWAYS use axle stands for safety,
I lost about 2/3rds of a litre once I removed the connector and bushing but I tried to catch as much as possible in a pan to measure how much was lost.
Thanks Sparkie, I have raised the front end with 2 jacks, and placed 2 axle stands under the cross-members.
I gained about 14 inches of clearance, but I will pick up 2 more axle stands tomorrow and jack up the rear, then see if I can get more clearance .
Access to the connector was a question I was going to ask but you stated you came in from the passenger side, so thats a done deal.
Providing the jacks hold and I am not crushed to death I will post how easy /hard this task is tomorrow.(as long as my arthritic wrists will allow me to type)
Dave
Dave
I have 2 SRT Sixes and both leaked from the NAG connector while it sits. The part is $15 at the dealer and PLEASE let them do it as it takes a computer and special dipstick tool to get the level right depending on temperature. PS> I work at a chrysler dealer and it is like a hundred dollar fix. DON"T DO IT YOURSELF with tranny!!!
I gave up, to old to twist and turn in a limited space, arthritis killing my wrists and back, will be going to the mechanic in the spring when the Pj's come off princess
BTW the NAG connector is just inches behind the bell housing, oh and one of mine broke while being removed and the tranny had to come out. It was free since still under warranty but the second one cost me $86
Originally Posted by PNA
Mine just started leaking this week. Was considering doing it myself but no time and I don't have appropriate ramps. Dealer quoted part at $15. Parts and labor at dealer was quoted for me at about $180 ---- but I'm hoping it will end up being closer to the $100 cost you noted. Pretty well sucks that these things leak like this (less than 10K miles on mine) but as usual, the forum helps us figure out these things and when we do to dealers with it, we can direct them right to the issue.
My service advisor say they are ripping you off
It is that I paid for actual time and they are quoting possible time. Tell them you will wait on it and watch the tech
Neither lost a drop since!
