Mercedes Engine Cover Mods and 74 mm Throttle Body
Old Oct 4, 2015 | 05:09 PM
  #81 (permalink)
Zoonami's Avatar
Default Re: Mercedes Engine Cover Mods and 74 mm Throttle Body
Originally Posted by Mrmiata
Take it another step for a few bucks.. get under hood sound and a little more out of it.. air temps are no worse than the OEM setup, and this is less restrictive..
Red 2004 2008 Chrysler Crossfire 3 2 3 2L Dual Twin Air Intake Kit Systems | eBay
So this system does not work if you have done the throttle body mod?
Old Oct 4, 2015 | 05:32 PM
  #82 (permalink)
LGV-XFIRE's Avatar
It works, but trust me you want to go ahead and do the full coool air intake and not hte warm air intake like the Ebay sale shows. I had a Spectre intake on mine and went ahead and got the tubing to make my cool air intake to replace the OEM intake. I also got a V8 intake to go with it. Not more than $130.00 for the entire intake setup and works great with the MAF and TB.
Old Oct 4, 2015 | 09:52 PM
  #83 (permalink)
That is not a picture of a V8 cover, V8 covers do not fit as I recall. They may look the same but the attachments points do not match the V6 engine.
The V6 front part does not fit the V8 rear part.
Only one V6 cover assembly fits, the other are too high and rub on the Hood liner. and mark the cover.
Old Oct 4, 2015 | 09:55 PM
  #84 (permalink)
Originally Posted by Zoonami
Is there a difference between engine cover 1120940004 and A1120901101? They look exactly the same and the 04 one matches the filter #. I can find a much better deal on the 0004 cover w/ filters than just the cover for 1101.
If there was no difference between the parts they would not have different part numbers.
If you are changing the cover then you should get the one that has the bigger filters or why bother.
Use #A 112 090 11 01 - main body.
Use
#A112 010 04 67- front piece.
Use
Filters, K&N's #33-2181, or OEM (paper) A 112 094 00 04
As described in post #1
Old Oct 4, 2015 | 10:00 PM
  #85 (permalink)
syfi's Avatar
The 1120940004 p/n is for the filter elements that fit into the A1120901101 engine cover box. (See post #1)
Old Oct 5, 2015 | 08:48 AM
  #86 (permalink)
LGV-XFIRE's Avatar
That's certainly a V8 cover. it's the S430 cover. You can use the V6 front with the V8 back.
https://www.crossfireforum.org/forum...1471-38172.jpg
Old Oct 5, 2015 | 08:57 AM
  #87 (permalink)
OK, I had V8 backs and they did not fit V6 fronts.
What are the part numbers for the record?
Old Oct 5, 2015 | 02:19 PM
  #88 (permalink)
syfi's Avatar
Here's pics of the V8 cover compared to the V6 cover...different front shrouds!
V6 has 6 slats/fake rivets....
V8 has 8 slats/fake rivets....
Old Oct 6, 2015 | 12:42 PM
  #89 (permalink)
Zoonami's Avatar
How do you have to modify the larger side of the tubes? I know you recommend the spacers going into the engine cover / air boxes, but what about the other end?
Would it make more sense to use a generic 3" intake tube? Something like this?
Amazon.com: Astra Depot Universal Washable And Durable Blue 3 Inch Multi Flexible Adjustable Motor Turbo Cold Air Intake Inlet Pipe Hose Tube Kit: Automotive Amazon.com: Astra Depot Universal Washable And Durable Blue 3 Inch Multi Flexible Adjustable Motor Turbo Cold Air Intake Inlet Pipe Hose Tube Kit: Automotive
Old Oct 6, 2015 | 12:50 PM
  #90 (permalink)
Zoonami's Avatar
What kind of intake tube set up is that?
Old Oct 7, 2015 | 04:49 PM
  #91 (permalink)
LGV-XFIRE's Avatar
here they are:
airbox: 112 094 00 04
https://www.crossfireforum.org/forum...mber-90534.jpg
Front cover: 112 010 04 67
https://www.crossfireforum.org/forum...mber-90532.jpg
Yes, it rubs the liner.
https://www.crossfireforum.org/forum...rbox-90533.jpg
I think I got the tubes for the W123 (they were cheap and on Ebay and just the right size for the airbox.) I got the Needwings Devil Horns, but only used the tubes through the front and not the horns themselves.
Old Oct 7, 2015 | 05:22 PM
  #92 (permalink)
here they are:
As mentioned previously 112 094 00 04 is a filter. That molded in number is showing you what filter fits.
I think V8 parts start with 113 xxx xx xx. Maybe not (?)
V8 air boxes mount in different positions if I recall and this puts the front part too far forward. I had all these parts and junked them at the tip.
Old Oct 12, 2015 | 11:35 AM
  #93 (permalink)
Zoonami's Avatar
I have a question about the intake tubes. Instead of the benz parts, I used generic autozone 3" tubes and cut off the ends of my old crossfire intake tubs to connect them into the front end radiator fittings for air intake.
Does the small size of those fittings basically make this entire mod useless, as the size of the air intake is the same as OEM?
Or do the bigger filters/tubes mean that more suction is created or something for more air? The cold air intake side of the tubes is the same as the original though.
Old Nov 4, 2015 | 06:43 PM
  #94 (permalink)
jayloukakis@hotmail.com's Avatar
Attachment 36079
Attachment 36080
I bought the V8 because some where on the forum I thought some one had mounted so I bought it doesn't fit so in the trash it goes bought one for the SLK320 and it fits perfect.
Old Nov 4, 2015 | 07:04 PM
  #95 (permalink)
The fittings by the radiator have holes which are uninterrupted but the filters hava million or more holes in them. The smaller holes in the filters have more restriction just because they are so small, if you have larger filters fitted then you have more holes and the restriction in each small hole is less of a problem as there are more holes in total.
You can compare it to a can with a smal hole leak and the same can with two holes the same size, the can with two holes will drain first.
Old Nov 5, 2015 | 03:02 AM
  #96 (permalink)
syfi's Avatar
Sorry to inform you but you will not gain any more air flow with the SLK320 cover. It is the same size/volume as the OEM cover. Only good for the bling factor. That's why it fits exactly. Just resale the V8 and SLK covers and get the correct C240/320 cover if more performance is what you're after. I bought mine from a salvage yard for $85. Search for a 2002 M/B C320 cover in your area HERE....
Car-Part.com--Used Auto Parts Market
Old Sep 12, 2016 | 09:54 PM
  #97 (permalink)
Pjj51's Avatar
I do have all the parts, here, in Buffalo, in the mail or on a Purolator truck. JIT(FTT), just in time for the tune.
I'm actually very good at planning and micro managing, by the time I have proved to myself I could do a project I forget about it and move on to the next. Just ask my wife, I planned for a big family, had one child and then moved on to the next project. It saves money and leaves lots of time for more planning.
Around the house I'm a virtual handyman.
My motto, how hard can it be?
As for the clubbin', there weren't too many seals on the ice this year, so we shot a few polar bears.
I love your approach 180. I built a stone wall around my house 20 years ago and left 3 of the 14 columns without caps on top...I pictured them in my mind and that was good enough for me. Virtual stone wall completed.
Old Sep 13, 2016 | 02:55 AM
  #98 (permalink)
Steve Jr's Avatar
So, it is virtually completed.
Old Sep 13, 2016 | 08:37 AM
  #99 (permalink)
Actually it was completed, driven, replaced by an SRT and is now virtually forgotten.
Old Nov 20, 2017 | 09:07 AM
  #100 (permalink)
White Thunder's Avatar
Anyone got a picture of said parts installed ?
