Engine oil
Old Jun 8, 2013 | 03:44 PM
mvagusta10's Avatar
Default Re: Engine oil
Thanks will replace battery soon. Also could you recommend me some good brake discs/pads for cross in uk? What do you think about zimmermann?
Old Jun 9, 2013 | 11:58 AM
My OEM battery started giving the click-click-click with spoiler popping up a couple weeks ago, I went right out and replaced it. The new battery went right in as a perfect fit, and only cost 100 bucks without tax n fees. Have not had any trouble since and smooth sailing now. If you have an OEM battery, you should replace it before it leaves you stranded.
Old Jun 9, 2013 | 12:45 PM
mvagusta10's Avatar
I know,know Firstly I want to change all fluids then battery, brakes and check suspension if there is any issues. Any discs suggestions?
Old Jun 9, 2013 | 07:20 PM
syfi's Avatar
Many here use the Rotex Gold Brake Pads which are Kevlar-blended, semi-metallic. But for the price you can't beat the Centric Posi-Quiet Ceramics.
As for the battery, even if you have the last production 2008 Xfire off the line, that battery is already over the 72 month limit. Everyone should have replaced their OEM Varta white battery by now.
Old Jun 9, 2013 | 07:33 PM
I like my new pads... Hawk HPS's ! Much less dust than the OEMs and they DO NOT FADE even in a hard stop from 80 MPH.
Preach on !
Old Jun 12, 2013 | 02:50 PM
mvagusta10's Avatar
Thanks what about rotors, which one are good?
Guys, I have replaced my oem battery which is from 2004 and is still working perfectly!!!
Thanks
Old Jun 28, 2013 | 12:10 AM
syfi's Avatar
Preach on !
Dang...I just pulled a Castanza. I didn't realize I did a double -dip in the same thread!
Old Mar 6, 2014 | 08:37 AM
I was thinking about red line or amsoil 5w30...
If you're considering using an AMSOIL product, their website recommends the European 5w40 Synthetic oil. Looks like it can be purchased for $7.50/quart + S&H charges. AMSOIL product spec sheet for my 2007 XFire NA Coupe is attached.
Later,
Old Mar 6, 2014 | 11:20 AM
syfi's Avatar
+1 on the Amsoil. You can't go wrong. I also use their Trans and Rear End fluids!.
Old Mar 7, 2014 | 11:06 AM
rfontham's Avatar
Just replaced my original Varta (11/04) with an Energizer AGM from Sams. About $150. Perfect fit. The old Varta still seemed good, no codes but after sitting a few weeks it would crank a few seconds before starting, also the spoiler has gone up at odd times. Sams has an Energizer that is not an AGM for about $105.
If I understand this correct the AMG has a gel inside and won't leak, also a higher cold cranking amps and an AMG loses about about 1 or 2 percent of power a month while sitting up compared to a regular battery loses that much a day. Other brands also have AGM batteries.
Old Mar 7, 2014 | 12:44 PM
edmoncwheeler's Avatar
Tip of the day: Go on eBay and order the Chrysler Blue Tooth OBD2 scanner for $39.72. It works through your Android or Apple device to give yuo constant readings on codes, and displays over 20 engine functions (temps, etc). Turn off codes, etc. I ordered one and will report on how it does
Ed
Old Mar 7, 2014 | 02:31 PM
Mrmiata's Avatar
I really need to order another one instead of switching between car and truck.. but not for that price.. LOL.
http://www.ebay.com/itm/Mini-ELM327-OBD2-OBDII-V1-5-Bluetooth-Diagnostic-Interface-Scanner-/120992229704?pt=Motors_Automotive_Tools&hash=item1c2bb2e948&vxp=mtr
Ralph289
Sep 12, 2021 11:15 AM
xfClifford
Mar 3, 2021 04:52 PM
PNA
Nov 12, 2020 04:44 PM
xfireohio
Jul 20, 2020 12:03 AM
skeet370
Jul 18, 2015 01:02 PM
