SRT 6 - Transmission stuck in gear P0715
Old 07-27-2018, 10:15 AM
DZL's Avatar
DZL
DZL is offline
Default SRT 6 - Transmission stuck in gear P0715
Hi,
I have a problem with my transmission, it is stuck in a gear and gives the P0715 code. I changed the transmission fluid (it was leaking a bit so I thought that might also be the issue) and the conductor plate and I went to the local shop to delete the code. I was surprised that it did not change anything, the car is still stuck in a gear and there the still the P0715 code. Could anyone help me and point me in a different direction?
Thanks
Old 07-27-2018, 12:30 PM
Default Re: SRT 6 - Transmission stuck in gear P0715
There is a round electronic connector that goes into the trans on the front, passenger side. Remove, clean both the connector and where it plugs in, replace the connector housing and “O” ring and reinstall. See if this helps solve the issue.
Old 07-27-2018, 02:11 PM
DZL's Avatar
DZL
DZL is offline
I changed the plug together with the conductor plate so this cannot be it.
Old 07-27-2018, 03:52 PM
Back in January 2015 Jessejamesrt6 had a similar problem and he replaced the same parts, he still had the code and the limp mode, it was determined that whoever was clearing the code was not doing a good job of it. A visit to another shop with a better computer to clear the code resulted in no code and no limp mode.
For what it’s worth that is what I found.
Old 11-09-2023, 10:51 AM
Spoiler
l’ll let you know.
Thanks
JesseJamessrt6
03-07-2015 02:27 AM
nashcrossfire
06-24-2013 05:26 PM
oconnor
07-07-2012 07:17 PM
oconnor
U.K.
07-07-2012 07:11 PM
Glockhit
04-19-2008 06:30 AM
Quick Reply: SRT 6 - Transmission stuck in gear P0715
