Removing Pinstripe
Old Jun 4, 2007 | 10:54 AM
ntenspy's Avatar
Default Removing Pinstripe
I am unsure if this was factory or added on by the dealer but I have a light silver pinstripe running from the rear to about the side vents on either side. I want this gone but, I am unsure how to do this, is it something I should have done by a shop or is it a DIY deal? I have read suggestions of using finger nail polish remover and then polishing/waxing afterwards, any thoughts?
Old Jun 4, 2007 | 11:56 AM
Romio's Avatar
Default Re: Removing Pinstripe
Not stock. Sry no tips on removal, can try Google.
Old Jun 4, 2007 | 12:20 PM
C_Plunkett's Avatar
If it's a piece of tape try heating the stripe with a hair dryer. It should melt the glue enough the remove the stripe. Use some goo-gone to remove any residual glue.
Old Jun 4, 2007 | 02:01 PM
ntenspy's Avatar
Fantastic, thanks for the info I will try this.
Old Jun 4, 2007 | 02:47 PM
andrew's Avatar
-C-I-C-C-I Associate Member
goo gone will not budge it... if it is painted on... finger nail polish remover will do the trick (just be sure not to get it on any exterior plastic areas). but some elbow grease will be required.
if its a pinstripe in tape forum... yep... a heat gun or blow dryer will loosen the adhesive and allow you to remove it with your finger nail.
cheers...
Old Jun 4, 2007 | 03:13 PM
ntenspy's Avatar
cheers...
I guess the first thing to do is determine if it's painted or taped. I hope it's tape because I gotta tell ya, I'm a newb and putting fingernail polish remover on my car makes me a little nervous.
Thanks for your help! I will post results.
Old Jun 4, 2007 | 10:32 PM
andrew's Avatar
Cool Re: Removing Pinstripe
if you can scratch the pinstripe off with your finger nail... its tape.
if not... its painted on.
no need to worry... the fingernail polish remover will not effect the factory finish.
you can trust my many many years of experience on this one.
Old Jun 11, 2007 | 05:04 PM
ntenspy's Avatar
Man, it was way easy, took me about 5 minutes and very little residue left. I guess I'm alittle protective hehe, thanks to everyone for the info, it looks SOOO much better!!!
Old Jun 11, 2007 | 10:50 PM
andrew's Avatar
~ glad to hear it went well ... so was it taped or painted on??
Old Jun 13, 2007 | 12:38 AM
ntenspy's Avatar
Opps forgot to mention, it was tape. It was fairly brittle but, still easy to remove.
syfi
Mar 28, 2026 04:14 PM
TerryR
Dec 13, 2019 03:27 PM
o55ie18
Oct 5, 2015 05:50 PM
brandoni
Sep 30, 2015 07:48 PM
55chevy
Sep 13, 2015 07:38 PM
