Wheel spacer specs
Wheel spacer specs
Hey Everyone,
I found Eibach spacers online and they seem really great, but I am not sure what size to get. I think the lowest they have is 10mm and the highest is 30mm. Does anybody know what size will make the rear tire's flush with the fender edge or at least the same as the front tires? Thanks!
-Sam
-Sam
on
Re: Wheel spacer specs
If you buy the eibach kits I believe they include lugs, not sure of the size on them though. I know there have been a couple people that have caused some issues by putting too long on the rear. (messes up the ebrake or somethin) Needswings has 10s and 15s on their site, I am pretty sure they would be able to tell you if the included ones will work.
EDIT ::: This Thread has info on the brake issue and some lug measurements, just look for the big red letters.
Originally Posted by samo59
Yea I have aftermarket chrome wheels. So maybe a 15-20mm might work. I'm guessing you also need longer lug bolts as FP has done. Where can I get those?
-Sam
-Sam
Go with the hub centric Eibach's, they are a little more expensive than some others out there, but trust me, I went through it once and you get what you pay for, IMO.
If they don't come with the extended bolts, you can buy them here. You will need the 55mm ball head for OEM wheels.
12 x 1.5 - 55mm Mercedes Benz Ball Head lug bolts
eBay Store: Search results for racing importer.
