Illumination control module
Re: Illumination control module
Canada has a different switch than the US. Maybe a Canuck has one stashed away. You can use the US switch by fitting a part you get from Crappy Tire. It will just turn on the low beams though when wired up.
You can get a used US ICM from eBay for around $100 to $150 plus shipping or find a scrapped Crossfire in Canada for the Canuck version.
Are you sure it is not the bulbs, fuses or multifunction switch?.
Hey Docsgwc, I see you are in Canada, is your car a Canadian market car (in km's)?
Our daytime running lights are all lights on, but unless you turn your headlight switch to on, the highbeams don't work.
Have you checked that?
If not, someone more experienced might chime in.
Good luck.
Steve
Good luck.
Steve
on
This sounds like an assumption, troubleshooting by assumption will waste time and money.
I'd bet the multifunction switch is the issue.
ZERACER
06-06-2019 05:01 PM
