Electrical problem suspected...?
Old Oct 24, 2022 | 07:00 PM
JCJ's Avatar
JCJ
Default Electrical problem suspected...?
Twice in the last week I ran to the store and when I came out the car wouldn't start - nothing - dead! Then after about 30 minutes, it was as if it would reset and it started right up and worked fine without a problem for days. Was this some kind of computer glitch or what? And does it automatically reset itself? Has this happened to others?
Old Oct 24, 2022 | 08:54 PM
Default Re: Electrical problem suspected...?
Dead? So you turned the key and there were no lights on the dash? Or you turned the key, the dash lit up with lights, but the starter would not engage - THAT is not dead, that is a "mystery no start" that we've known about since 2007.
READ:
https://www.crossfireforum.org/forum...-no-start.html
I had this happen to my car ten days ago, just got my RCM back from DJ today, in fact. All fixed.
Old Oct 25, 2022 | 10:35 AM
It can also be a bad or weak battery connection.
Old Oct 25, 2022 | 12:44 PM
THe test is the fan.
Car won't engage starter.
  • Leaving key at "ON" for 30 seconds causes fan to run at HIGH speed - RCM is at fault (no output from the Engine Control Relay, so the ECU is not powered up).
  • Leaving key at "ON" for 30 seconds does not cause fan to run at high speed - very likely battery, as this indicates power is available to the ECU but not enough voltage to engage the relay in the Pulse model, so no starter.
greenlightracer
Apr 26, 2010 04:50 PM
cfdrummer
Jul 25, 2008 05:24 PM
StealthESW
Jan 29, 2008 11:14 AM
fmccamant
Aug 25, 2006 11:15 AM
The King
Apr 2, 2004 09:04 PM
