Air Conditioner Seems to be Intermittantly Shut Off
Old Jul 23, 2017 | 10:30 PM
Atty4u's Avatar
Default Re: Air Conditioner Seems to be Intermittantly Shut Off
I own 2007 Crossfire, 6-speed, 110,000, daily driver in TUCSON, Arizona, AKA Hell!
Just recently my air conditioner started getting goofy on me. Run-stop-run for reasons I could not nail. Did a bit of plugging around, saw too many refer to the "HVAC resistor," so for $200, I replaced it, with the air cabin filter. Total time, 35 minutes for both.
Now that I know what I'm looking at, I don't think I had to replace the resistor. My cabin filter was so dirty that the air flow necessary to keep the resistor cool was non existent. If I had not purchased the resistor, I would have tried to see if changing the filter alone would have been enough to fix my problem.
But I replaced both, and for 4 days, my air conditioner "gremlin" appears to be gone. If it comes back soon, I'll clue you all in.
Now if I can find out how to run my "P0410" code to ground. Ordered the check valve, $30, it is cheap, easy, and it is a start. Next, I'm going after the relay. Then a hammer, 10lbs, should do the trick. The damn thing doesn't stay on long enough for me to recreate the problem on demand.
News to follow on that point as well. So, here is driving with A/C in Tucson. Let's see if it holds out.
Last edited by Atty4u; Jul 29, 2017 at 10:56 PM. Reason: UPDATE: A/C problem seems fixed.
Old Jul 24, 2017 | 06:49 AM
Congratulations on the fix and welcome to the forum !
Send an email to tighed1@hotmail.com about the RCM, he will overhaul it including new relay for around $30, well worth it unless you are a very experienced electronics tech.
Old Jul 24, 2017 | 06:20 PM
tighed1's Avatar
I was in Tucson 3 times last week! Where were you!
I'm close. Sierra Vista.
Old Jul 29, 2017 | 10:53 PM
Atty4u's Avatar
I live in the North West part of Tucson, and I travel regularly to Florence, AZ to visit "guests" of our federal government.
If you got a clue about the P0410 intermittent air pump code, I'm all ears. At this point, I'm going to start replacing the relay next. The pump seems fine, and there is no corrosion on the leads to speak of.
syfi
Mar 28, 2026 04:14 PM
Valk
Jul 12, 2021 09:49 PM
franklindm
Mar 14, 2020 12:23 PM
TerryR
Dec 13, 2019 03:27 PM
Sep 28, 2015 07:40 PM
