Seat Relay
on
Re: Seat Relay
The seat relay has nothing to do with the door other than the door ajar switch. What door are you talking about and what's wrong with it?
on
Re: Seat Relay
Post number one lists the part numbers.
MB #002 542 22 19
Siemens Part #72KD305
Chrysler #05104857AA?
on
Re: Seat Relay
If you don't want the car fixed, but you want to spend a lot of money on not getting it fixed, take it to a dealer.
The seat relay is down under the dash and it fails at times. You can change it (they plug right in, and cost around $35) or you can take it out and resolder the broken paths (which is what usually goes wrong with them).
pjd2025 (03-31-2024)
on
Re: Seat Relay
Here is the relay:
Your Parts Search Returned 1 Part(s)
Like I said, they just plug in. If NEITHER seat moves, it's almost certainly the relay - happens all the time.
Kleito, Charlie in Atlanta, can tell you how to get to the relay - it's really easy. Click in his user name here:
https://www.crossfireforum.org/forum...tml#post849563
... and send him a message.
Re: Seat Relay
See the attached PDF for details of the circuit. CLICK
Re: Seat Relay
Yes, I know that first is relay and next fuses. I read all this topic.
At the moment I check only relay but I think that power not goes to relay from ignition switch.
Can I broken something if I give power directly to fuses 21, 22?
This is not urgent, I have time for repair it becouse I not change seats position too often.
