SRT6 convert blank switch to on/off
Old Dec 31, 2011 | 12:34 AM
srt6-xfire's Avatar
Default SRT6 convert blank switch to on/off
I own a SRT6 and was wondering if anyone has converted their balnk switch on center console to an on/off switch to run interior lights? The blank switch I'm refering to is the spoiler switch on the NA's.
I purchased a second Alarm switch thinking it would work but it only sends power out when depressed it will not work as on/off toggle. Anybody have any ideas?
Old Jan 1, 2012 | 02:33 AM
svo's Avatar
svo
Default Re: SRT6 convert blank switch to on/off
I was thinking of using that for a on/off switch for a radar/laser jammer
Old Jan 1, 2012 | 12:57 PM
latemodel21's Avatar
if you cant find the proper switch, here is a relay circuit that will latch and unlatch from a momentary switch (and unlatch when you turn the key off)
Special Applications with SPDT Relays, Diagrams
Chris
Old Jan 5, 2012 | 03:47 PM
srt6-xfire's Avatar
Chris
That is great information Chris beacuse that is exactly what the the alarm switch I purchased does, I just don't know how to purchase the relay described in the diagram to connect to my switch.
Dave
Old Jan 5, 2012 | 04:26 PM
that circuit uses 4 (yes 4) standard SPDT relays .... available at kragens, etc ... cheaper online
example ... http://www.ebay.com/itm/12-Volt-Rela...item1e6918070d
1n4001 would be a good number for the diodes
Chris
Old Jan 5, 2012 | 04:32 PM
MikeR's Avatar
wow.... I haven't heard of Kragens since I left San Jose......
Old Jan 6, 2012 | 07:39 AM
srt6-xfire's Avatar
example ... 12 Volt Relay Car Alarms SPDT 30 40 amp 5 prong Lifetime Warranty | eBay
Chris
Thank you very much for your help, I think I'll keep serching for that on/off switch not sure I have enought room in dash for 4 relays and wiring.
Dave
Old Jan 6, 2012 | 08:13 AM
My sw is for opening and closing my exhaust dumps,, works great. jim
Old Jan 6, 2012 | 08:32 AM
srt6-xfire's Avatar
OK I'm curious did you use a chrysler or MB sw or did you go rouge and make your own?
Old Jan 6, 2012 | 09:11 AM
the rear wing sw on the limited was used ,it was by Rudy, when he put my V8 into my car. jim
Old Jan 6, 2012 | 09:24 AM
srt6-xfire's Avatar
Yes I had talked to Rudy prior to starting thread, he had qouted me a price then got really busy, so I thought I might be able to try on my own. Rudy did say If I got some people together he would make up a few rather than just one.
So to everyone reading this if you would like to have a on/off switch to replace your "blank" where "wing sw" would be I'll start a list to give to Rudy.
Old Jan 6, 2012 | 09:49 AM
yea it is not just a swap out ,,there is a lot of work just to get it to work as a toggle sw.
Old Jan 6, 2012 | 12:45 PM
Dave
If space is a concern, you could do this with one IC and a transistor (T flip flop). But if Rudy already has a working solution for this, I bet it is a good one and I would go with that.
Chris
Old Jan 6, 2012 | 08:42 PM
bluecoupe's Avatar
I'd be interested pending price.
Old Jan 16, 2012 | 12:10 AM
mjgroves's Avatar
Count me in as well. I dont know *what* exactly I need a switch for, but I need one.
Old Jan 16, 2012 | 10:48 AM
Daniel454's Avatar
I converted my blank to control my fog lights.
Gave me the ability to run the fog lights with high beams as well as allows them to default on anytime the headlights are on so I do not have to remember to pull out on the headlight switch....
It can be done with one small latching relay and one standard automotive relay.
The latching relay is essentially the item that will turn the momentary pulse to a constant signal. Unfortunately I could only find these in low current circuit board style so you must then take that latched signal to a full size automative relay to handle the current needed. Plenty of room in the dash for this though...
Many options exist for that latching relay, I chose a FRT3-SL2 Relay:
http://www.led-switch.com/Relays.htm
http://www.khalus.com.ua/data/chips/chameleon-relay/pdf/frt/frt3.pdf
Now if Rudy puts something together it would be a LOT cleaner and simpler I am sure, but this will work JUST FINE if you have the time to make it happen.
Here is my original thread with more info of exactly what I did. https://www.crossfireforum.org/forum...rks-fixed.html
Old Jan 22, 2012 | 04:38 PM
Mrmiata's Avatar
Hope you remember to default to off when in Oklahoma unless weather warrants their use. It will get you a ticket here for having them on for the fun of it.
Old Feb 26, 2012 | 04:33 PM
srt6-xfire's Avatar
OK I could not wait for switch to made so I, did the american thing and Improvised.
I bought 3 switches from web Site
Round Rocker Switch - 12V LED - Prewired in Blue, Red, Green, White, Amber, Pink
I Tapped into hot wire from hazard switch put inline fuse and mounted switch inside center console box, attached is a picture of finished product.
Old Jun 8, 2019 | 03:50 PM
WD40's Avatar
I used a "standard" $5 relay which I switched-on (ran power to the driving lights) whenever the running-lights are on.
Old Jun 8, 2019 | 05:53 PM
You already have an ON-OFF switch for the interior lights on the map light. I guess you would have to have the switch hooked up to a relay if you needed another.
ZERACER
Jul 7, 2020 10:21 PM
BrenLW
Aug 4, 2015 01:29 PM
blacktouring
Jul 31, 2015 11:50 AM
axnguyen
Jul 21, 2015 11:41 AM
Fildo Dog
Jul 6, 2015 05:20 PM
