Climate control knob alignment
Old Dec 1, 2023 | 02:46 PM
Bcfichter's Avatar
Default Climate control **** alignment
I removed the climate control assembly to troubleshoot and replace, and turned the heat selection dial by mistake that turns two shafts that the climate control assy
engages with reinstalled. How do I realign the shafts property so that when the dial indicates where the air is going , that it is aligned properly?
Bruce
MODERATOR NOTE: If you are re-installing your climate control module and cannot get it to go back in, see post 4!
Old Dec 1, 2023 | 04:23 PM
Default Re: Climate control **** alignment
Bruce
Turn the square spindles that stick out from the firewall and set them the middle click position. Then turn the ***** so that they are vertical. Then slide them together which is easier said than done. You well see that one of the square shafts is longer than the other, slide that one on first. It is a tricky job though keeping the square spindles in position.
Good luck.
Old Dec 3, 2023 | 12:03 PM
Bcfichter's Avatar
Thank for the tip!
Old Dec 7, 2023 | 08:57 AM
Turn the square spindles that stick out from the firewall and set them the middle click position. Then turn the ***** so that they are vertical. .Then slide them together which is easier said than done. You well see that one of the square shafts is longer than the other, slide that one on first. It is a tricky job though keeping the square spindles in position.
Good luck.
I completely agree with onehundedr80's feedback above. I made getting the shafts re-inserted into their respective spindles a little easier by using some split corrugated wire loom to extend the spindles for re-alignment. Took me a couple of tries, but worked like a champ & no need to remove the wire loom afterwards. Something that also might help is to remove the center console HVAC vent located directly above. Gives you some improved visibility & access when re-installing the HVAC Control Module.
Old Dec 7, 2023 | 10:49 AM
Boy oh boy, we have some smart people on this forum, great idea.
Old Dec 7, 2023 | 02:05 PM
Coming from you, that's high praise. Thanks!!
Old Dec 18, 2023 | 04:47 PM
WOW. I never thought of that.
Probably not needed with your wire loom idea.
Old Dec 19, 2023 | 12:02 PM
Yes! Great idea! Just make sure the keyway is aligned on the two shafts. They are not forced but if so without alignment, you sure do not want to break the sockets at the firewall side of those shafts. Just an FYI reminder.
Old Dec 28, 2023 | 10:17 AM
I've made this a "sticky" and added a note to post #1.
Toolman
Sep 16, 2021 06:21 PM
RoomSeven14
May 5, 2018 09:59 AM
RoomSeven14
Aug 3, 2017 01:18 AM
atlsrt44
Jan 16, 2015 09:59 AM
helm
Dec 30, 2003 01:58 PM
