Help 😬
Old 05-01-2018, 04:21 PM
JoJoCarver's Avatar
Default Help 😬
Hello everyone. I bought my first Crossfire yesterday a coupe. Couple of silly problems. If I lock with the remote, I get no audible signal and within a couple of minutes the indicators start flashing...as if the alarm has been tripped, but again, no sound. The dealer had fitted a new battery. I seem to recall another car some years back when this happened after anew battery...any thoughts?
Also, the spoiler doesn’t seem to deploy at 60mph. It operates from the switch.
Old 05-01-2018, 05:01 PM
Default Re: Help 😬
As they came from the factory there was no audible sound, the lights just flashed once or three times. If the lights flash when you say then the alarm siren is probably dead. You can replace it with a siren that beeps, once or three times at the same time the lights flash.
The siren is under the cowl in front of the windshield, disconnecting it would confirm my diagnosis.
One flash for opening and three for locking.
You can forget the new battery causing the problem.
Old 05-01-2018, 06:19 PM
JoJoCarver's Avatar
Default Re: Help 😬
Thankyou, I’ll check in the morning. Any thoughts as to why it may flash after several minutes, as if the alarm had been tripped?
Old 05-01-2018, 06:23 PM
Default Re: Help 😬
I thought I covered that in my post, you only mentioned the lights flashing after a couple of minutes.
Old 05-01-2018, 06:27 PM
JoJoCarver's Avatar
Default Re: Help 😬
Are you saying that because the siren is possibly faulty, that’s why it looks like the alarm has been tripped? Rather than a fault with the alarm itself?
Old 05-02-2018, 12:15 AM
Default Re: Help 😬
Huh!
Unplug the siren.
mrcrossie
06-24-2018 03:29 PM
Highdollarcarguy
06-06-2014 05:21 PM
FabianMoody
02-23-2014 10:03 PM
lillybee
11-09-2013 11:40 AM
NeverEnough
08-01-2010 05:32 PM
Quick Reply: Help 😬
