Southeast Forum Serving AL, FL, GA, KY, NC, SC, TN.
Sticky ignition switch
Old Mar 1, 2013 | 01:32 AM
CMF's Avatar
CMF
Default Sticky ignition switch
ANYONE NEAR JAX., FL. OR SAVANNAH, GA. KNOW ANYONE TO FIX THIS ISSUE-'05 CONVERTIBLE?
Old Mar 1, 2013 | 07:58 AM
Default Re: Sticky ignition switch
I had myself been putting this off for the 2 years I have owned my roadster, but lately it has been getting a bit more troublesome, so night before last I printed out the 10 page DIY pdf and dove in.
Surprise !!! Not as hard as you might think !
Couple of hints :
1. the transmission interlock cable is disconnected by pulling DOWN on the 2 release ears, NOT sliding back.
2. it is much easier to get to the ignition electrical plug if you do that AFTER releasing the clamp and rotating the assembly ( front up, back down ).
The most difficult part for me was getting the lock cylinder and locking ring back in after the repair, but I just kept fiddling and it finally went back together.
Total time I spent was about an hour and a half.
Old Mar 20, 2013 | 10:25 AM
gfalcone's Avatar
Couple of hints :
COME DO MINE !! Right now I have to keep a key in the switch, I remove it, and it's hour or more until I can turn the key for the car to crank over ! I found leaving the key in ...no trouble. Pull that sucker out !! BAMB...
ps. Crossed over 119,000 this morning !! yes, 431.....
Old Mar 20, 2013 | 10:39 AM
Drive down here one day after work and we can do it.
I'm now a certified lock-fixer.
Old Apr 7, 2013 | 04:19 PM
gfalcone's Avatar
ALAXFIRE and I did mine about two weeks ago. It was intimidating to me as my skill set with a screwdriver and wrenches aren't so good. But I'll tell ya, it wasn't all that hard to do ...honestly. To me hardest part was putting the screws back in the panels once the switch was back in place.
IT'S been two weeks and switch has been working like a charm !!
Old Jun 26, 2014 | 05:53 PM
CMF's Avatar
CMF
Angry Re: Sticky ignition switch
2005 CROSSFIRE CONV. IGNITION SWITCH FINALLY LOCKED UP , FOR GOOD, AT 47K. SUCKS. $1280 BIG ONES TO FIX AT DEALER. TOOK ME 1.5 HRS. TO GET KEY TO TURN TO DRIVE OVER. ANY WAY TO GET $ BACK FROM CHRYSLER????
Old Jun 26, 2014 | 07:03 PM
Mrmiata's Avatar
Go back to dealership with a brick at midnight for a shopping spree?
Old Jun 26, 2014 | 07:38 PM
xme's Avatar
xme
Sadly, pretty much this... Doubt you'll find anything for the XF though
Old Oct 11, 2022 | 11:42 PM
Denny White's Avatar
So, the goal for the stuck key is to get the spring and pin out from under the hatch on the ignition assembly? So I followed the text and also the Utube vid and did it. Thank you forum. So nice to get somewhere and not have to worry if I can get the car started. The Utube vid helped and I followed the advice of first removing the assembly and then, with a pair of channel locks I removed the harness from the back. Steering lock cable was fairly easy to detach but on reinstall I attached it like the harness before putting unit back in the strap. I guess this problem came about long after Chrysler quit production otherwise there should have been a recall.
Old Oct 12, 2022 | 09:32 AM
Instructions are here.
Index of Crossfire problems and repairs - CrossfireForum - The Chrysler Crossfire and SRT6 Resource
fastfred
Nov 5, 2018 09:47 AM
fastfred
Sep 24, 2015 03:05 PM
pjm30144
Nov 11, 2013 06:24 PM
Neophyte
May 23, 2012 05:57 PM
doug5639
Sep 11, 2011 10:19 AM
