Oil
Old Nov 27, 2009 | 04:04 PM
Bodog's Avatar
Default Re: The Oil Change from Hell!
Originally Posted by Bladecutter
Nope, just don't try to start the car if the temp gets down to freezing
Thanks - You don't know how funny that comment is - I live in Australia where its coming into summer - at the moment we're having a heatwave with a number of days hitting 100 degrees F. There is ZERO chance of it hitting 0 degrees here in the next 6 months
I just came across this thread which also discusses dealers stuffing up with Oil types
Old Nov 27, 2009 | 04:15 PM
summer, I'm coming down to visit...it's just starting to be winter here....sucks....ok, back to the oil thread. There is an update thread just started about oil changes as well...good luck...but I will stay with my Mobil 1. I was using this product since 1990 and wouldn't change for reasons given in the other thread...
Old Nov 27, 2009 | 07:04 PM
Nope, just don't try to start the car if the temp gets down to freezing.
Also, 15W-40 is typically a diesel engine oil weight. It will decrease your fuel economy.
BC.
These questions are for anyone who KNOWS the answers.
1) Ok, so why the 0 weight oil anyway? I mean, my 85 truck called for 10W30 and my 1993 truck called for 5W30 and now the car calls for 0W40... why this trend? Why are manufacturers calling for thinner and thinner oils?
2) Why the recommendation for synthetic oils?
An additional note: In the past two trucks I've owned, which I mentioned above, I ran the recommended oils until about 15,000 miles. At that point, I switched to 15W40. At around 85,000 to 100,000 miles, I changed to 20W50. I believe it best to use a heavier oil in a high mileage motor, and I also believe that heavy oils in general are best. When I told a guy years ago that I was running 20W50 in my 93 truck I mentioned above - he told me I'd ruin the engine because the oil cap says "5W30 only" on it.
Well, it is owned by a friend. It is still running and rolled over 383,000 miles on my birthday this year. Original engine, of course.
It bugs me to put 0 weight oil in an engine, but I am doing it. Someone educate me. Please.
Old Nov 28, 2009 | 10:37 AM
Bladecutter's Avatar
There are several reasons for this:
First off, Fuel Economy is the number 1 reason.
A lighter weight oil is easier to push through the engine, and requires less power to push through the motor when cold, and warming up to temperature. This allows Honda, Ford, and everyone else who puts 5W-20 weight into their small little 4 cylinder cars to get 30+ mpg during EPA testing.
Second, HP is the second reason.
As I said above, a lighter weight oil doesn't rob as much hp from the engine.
This allows a manufacturer to say their car has a 1 or 2 hp advantage over the same engine that used the heavier weight oil.
Third, proper function of variable cam systems.
Some car companies have very sensitive camshaft adjusting mechanisms, like Porsche, and if you put in too heavy an oil, the cam advancing functionality is delayed, which then sets off a CEL. If the cam advancing action is delayed too much, you risk having the valves hit the pistons at cam changeover points. Porsche then sends off your oil for testing, sees that you have the wrong weight oil in your engine, and denies your warrantee claim.
Fourth, and my final argument is cold start protection.
As I've implied before, a higher first number is a thicker, heavier oil.
This requires that the engine work harder to push it through to all the points in the engine. Also, this higher pressure from the thicker cold oil will force the bypass valve in the oil filter open, allowing cold, heavy, dirty, contaminated oil into your engine, accelerating wear. So you may think you are protecting your motor better, but in reality, you're not.
Synthetic oils are capable of handling higher temperature environments without breaking down, getting foamed, and turning to mist than conventional oils. This allows a car to be pushed harder, tow longer, and rev higher than a car with conventional oil, where the oil breaks down, no longer protects, and parts either wear out, or seize.
Also, you can run the oil longer in the engine, safely, and save the environment from nasty used oil that is changed more frequently. But then again, most Americans truly don't care about the environment, and only give lip service about it. Can't break their tried and true habits of changing the oil every 1k to 3k miles, and they never needed to rebuild and engine after 150k miles on this car, blah, blah, blah.
Personally, I would have recommended sticking with the recommended oil viscosity until you are completely out of the Power train warranty period, just to prevent any possible harassment of the dealer and manufacturer. And with todays engines, so little wear occurs after only 15k miles, switching to the heavier oil doesn't add any protection, it just makes the car harder to start when cold, and increases wear under cold starts, and taxes your car's battery more.
After you are out of the warranty period, its all on you to fix the engine, and no one really cares what you do, except for the person who has to buy the car/truck/motorcycle/lawnmower/whatever from you afterwards. Honestly, if you operate your vehicles just like everyone else on the planet, you aren't seeing any extra benefit from the heavier weight oils, because you aren't pushing the engine hard enough to get it to the levels where 5W-30 isn't thick enough to protect the engine.
Here's a quick comparison:
Mobil Clean 5000 5W-30 (conventional oil) Flash point is 392 degrees F, Pour point is -27 degrees F.
Mobil Clean 7500 5W-30 (synthetic blend) Flash point is 392 degrees F, Pour point is -44 degrees F.
Mobil 1 15W-50 (synthetic oil) Flash point is 455 degrees F, Pour point is -38 degrees F.
Mobil Delvac 15W-40 (diesel oil) Flash point is 456 degrees F, Pour point is -22 degrees F.
Mobil 1 5W-30 (synthetic oil) Flash point is 446 degrees F, Pour point is -54 degrees F.
As you can see, the Mobil 1 5W30 has the best cold weather protection in case you live in Antarctica, and really doesn't give up much high temperature protection in comparison to the two heavier oils. Typically, a normally operated car or truck engine runs between 180 and 260 degrees F for oil temps.
Of course, there are points in the engine where its going to be a lot hotter than others.
Piston rings, and cylinder walls will see the highest temperatures, since that is where combustion takes place at. The higher the temperature the oil can withstand there, the less wear will occur, and the less oil your engine will burn in the long run.
You asked for answers, and there you go.
BC.
Old Nov 28, 2009 | 02:43 PM
Mobil 1 5W-30 (synthetic oil) Flash point is 446 degrees F, Pour point is -54 degrees F.BC.
Just a slip of the fingers here.
Mobil Delvac 15W-40 is a synthetic oil for diesel engines.
Old Nov 28, 2009 | 04:09 PM
Default Re: Oil
Thanks B.C. My half-brother is a retired GM executive and he was the first one to tell me about the "1 or 2 mpg EPA" thing. He didn't get into all the rest of the technical stuff YOU did, and he probably doesn't even know all of that.
But, overall, yours was the answer I was looking for. I made my post so long, so as to get SOMEONE who REALLY KNEW to answer. Not sure how you would have answered had I just asked: "Why zero weight oil?", but I AM happy with your answer. Thanks again.
I"m going to print and save it, if you don't mind.
But before I go, one thing: Could you have included 0W40 in your chart?
Old Nov 28, 2009 | 06:24 PM
Default Re: Oil
Can't find the cold pour point for Mobil 1 0w-40.
The Flash point is 446 degrees F, which is the same as the 5W-30.
Chances are, the 5W-30 and 0W-40 are made from the same stock, with a couple different additives to give the 0W-40 the edge in lower temps, and for meeting all the different specs that it does.
There is a saying I kind of want to bring up in the terms of Mobil 1 0W-40, because of how many standards it has to meet all at the same time:
Jack of All Trades, Master of None.
I don't use it, but I have my reasons why which I have pulled from lots of other people's research, and oil analysis results.
BC.
Old Nov 28, 2009 | 08:41 PM
Default Re: Oil
BC.
Mobil 1 0W-40
Pour point is -54 deg.C (-65 deg.F) So thats even better in Antarctica.
For those interested in trivia -40 deg.C = -40 deg.F
Info was gathered from the following site.
http://mobil1.ca/Canada-English/File...il_1_0W-40.pdf
Just because a product meets many standards I do not think you can say its a Jack of all trades, if it meets or exceeds those standards it is because of its wider range of capabilities. In many cases these standards probably overlap or are nearly the same.
TerryR
Dec 13, 2019 03:27 PM
Oct 1, 2015 01:42 AM
Sep 28, 2015 07:40 PM
stlas69
Sep 14, 2015 06:45 PM
lazorouss
Sep 11, 2015 09:16 AM
