Check Engine Light - HELP
Old Jan 6, 2007 | 03:30 PM
TP Xfire's Avatar
Default Check Engine Light - HELP
I have a 2004 Crossfire Coupe Limited (40k miles), and recently the Check Engine light has come on (after I filled up the tank). First thing I did was check the gas cap, it was fine, but the light is still on. I thought maybe it was poor quality Gas so I put some of the fuel cleaner in that tank and the next day the light actually went off. But it only stayed off for about 2 hours, and now it's back.
While the car is warm (after driving for 15 min or so), if I turn off the car and try to start it back up it gives me trouble and won't turn over. It take about 4 tries until it finally starts back up. It starts just fine on cold starts.
Other than that the car runs normal! Before I take it to the dealer to be fixed, does anyone have any advice or has anyone experienced this? And how much did it cost?
Thanks in advance for your help!
- TP
Old Jan 18, 2007 | 02:29 PM
X-FIRE GUY's Avatar
Default Re: Check Engine Light - HELP
Do you know what codes you have ?
Old Feb 16, 2007 | 09:59 AM
ndfrspeed2's Avatar
What a coincidence... My '04 recently hit the 40K mile mark... this morning the check engine light came on. TP did you end up taking yours to the dealer??
Old Feb 16, 2007 | 11:20 AM
Ronman's Avatar
I have similar mileage and mine was also having a hard time starting. I have a defective camshaft sensor, its on order.
Old Feb 16, 2007 | 03:29 PM
Maxwell's Avatar
is that a warrantee part?
Old Feb 17, 2007 | 05:52 PM
Ronman's Avatar
Yes warranty part, I have an extended one. Otherwise the part is like $147.
Old Feb 17, 2007 | 08:16 PM
Maxwell's Avatar
- TP
Did you get your car scanned by a dealer? let us know what sensor error is at fault.
I have heard of other cars with a pressure sensor near the tank would fail, but it could also be a hose connection at some port that blew off due to high pressure in the tank. I would need to look at the factory manual for a diagram and see where the vent hoses and ports are located.
Old Feb 17, 2007 | 08:19 PM
RPM's Avatar
RPM
Moderator
- TP
You might want to run it by an auto parts store and let them scan it. I think Auto Zone & Advance Auto do them for free.
Old Feb 17, 2007 | 08:27 PM
Maxwell's Avatar
Can they scan late model Mercedes cars? Are the european OBD ports the same?
Old Feb 17, 2007 | 08:29 PM
RPM's Avatar
RPM
Moderator
I'm not sure. Can't hurt to call or stop by though.
Old Feb 17, 2007 | 08:39 PM
MI1XFIRE's Avatar
All OBD II ports are the same worldwide...
Old Feb 19, 2007 | 10:15 PM
04xfirecoupe's Avatar
I had my scanned by Advanced Auto and Auto Zone today, so yes they can.
Old Mar 28, 2007 | 09:19 AM
MrQue05's Avatar
- TP
TP,
What was ever the outcome at the dealer? I am curious because my XF has started to do this same problem. It didn't actually start until I started using the "quick start" feature our cars offer. Not really sure if its called the quick start but I'm sure someone can explain more in-depth. I'll be going to the dealer later this week. Are there others that have had this besides those of us who have voiced here? My mileage is at approx 42K.
Later,
Q
Old Dec 18, 2008 | 01:14 PM
mar322psu's Avatar
My car just turned 43K and yep its the same the car won't start at all until I give it at least 30 to 45 min wait since last turned off
Old Dec 18, 2008 | 01:25 PM
tighed1's Avatar
Wow! First post in over two years and you bring up a post that's nearly two years old.
Welcome back! Now, what exactly is your problem?
Hoppy
Dec 7, 2018 07:36 AM
jgreen
106
Sep 18, 2017 11:46 PM
spoiler
Sep 2, 2015 08:56 PM
axnguyen
Jul 21, 2015 11:41 AM
Mark McKay
Jul 17, 2015 01:18 PM
