Shut off spoiler?
Old Feb 8, 2005 | 07:44 AM
TSaxMan113's Avatar
Default Re: Shut off spoiler?
I have to admit that I used to be of the mindset that the spoiler actually contributed to the handling of the car when at speed, but after finding out that it only provided 40lbs of downforce at 80mph I quickly changed my mind. As neat as it is to think that we've got an active spoiler that is actually beneficial, 40lbs just isn't that much and won't hardly make a difference in the handling - even when braking.
Old Feb 8, 2005 | 08:06 AM
saldous's Avatar
Just get a fat friend to sit in the passenger seat, that will give you more than 40lbs!!
Old Feb 8, 2005 | 09:53 AM
andrew's Avatar
-C-I-C-C-I Associate Member
i've had my spoiler fuse pulled since ownership for nearly a year and a half. no problems here...just a cleaner look from the rear.
i might run up to 100 on occasion...still feel stable as always.
Old Feb 8, 2005 | 04:33 PM
Bob G's Avatar
Originally Posted by Galen Dracos
Been meaning to try and find the fuse. Thanks for quick info (saves me time) and the heads up on the Tone'ing. Bummer.
I have concerns about winter-ice freezing it closed. I assume the motor has a pressure limit (eventually give-up if its frozen or otherwise stuck in the closed position) instead of just burning out the motor. But, anyone know for sure? Or, just want to try it out on their's? :twisted:
Galen:
I was also worried about it freezing and burning out the motor, however, I have found it to go up and down without issues in up to -38 C. I wouldn't wash it and just take it out, without making sure that you have wiped all the water off under the wing though. Mine goes up at about 60 mph.
wlincourt's comment about pulling the fuse and the tone going off at around 85 mph seems to be what all the others said in previous posts also.
Old Feb 8, 2005 | 04:54 PM
saldous's Avatar
Originally Posted by Bob G
Galen:
??? what about when it is raining? Dude it is designed to work in the wet too you know!
If you have an accident and the insurance company find out you had pulled a fuse on what Chrysler says is a "Safety" feature with the spoiler, lord help you...
Old Feb 8, 2005 | 05:31 PM
Bob G's Avatar
saldous:
Doesn't rain here at -38 C.
I also agee with you on the saftey deal, I just use my spoiler as DC intended.
I don't have any issues with the little spoiler. I am going too fast when it's up to worry about how it looks. When I'm going slow enough for people to get a good look, it's down already. Unless you drive an SRT-6!
syfi
Mar 28, 2026 04:14 PM
Lockhouse
Mar 20, 2024 04:50 PM
Valk
Jul 12, 2021 09:49 PM
Reliableron
Oct 17, 2015 10:19 PM
davidc90
Sep 6, 2015 10:37 PM
