Is it worth CHIPPING my 2005 Roadster?
Old Jun 13, 2004 | 02:46 PM
David Burns's Avatar
Default
Originally Posted by AZ Outlaws
David, Am I reading you correct in that Wes got a bigger boost from the K&N's than he did with the chip???
Go read the original Wes chipping thread. See if you come to same conclusion. Maybe I just reading it wrong.
Old Jun 13, 2004 | 03:51 PM
AZ Outlaws's Avatar
Default
Are you kidding??? He's written a 12,000 page manuscript about chipping under who knows how many threads. It would take half a day to find it. :wink: :wink: :wink:
Old Jun 13, 2004 | 05:56 PM
Default
I found it in about 3 minutes. :wink: ops: :wink:
https://www.crossfireforum.org/forum...pic.php?t=1146
Old Jun 13, 2004 | 06:03 PM
WesMichaels's Avatar
Default
I can't even remember right now and my notes are in my office.... I think.... But if I remember correctly the performance increase was pretty close and the first tests were done with nothing more than a stop watch. I wish I had done a more reliable baseline before I started changing things. I remember that before I went and got the chip done that I took my K&Ns out and did some 0 - shift to 3rd runs with a stop watch and then reinstalled the K&Ns and did the same. After the chipping it's shifting to 3rd at a faster speed (about 61 mph. Before it shifted right about 57 mph) so that kind of skews the results using the stop watch and shift into 3rd method. The I got the G-Tech pro and ran some tests with that. I don't have a ton of confidence that the G-Tech is very accurate I'm still planning on getting some real Dyno numbers.... One of these days, when I not so busy.
I think that I actually got more of a total performance boost from the chip, then the K&Ns. Mainly because of the other factors that the chip improved... Shifting crisper and shift point change. Also got better mid to high range torque with the chip.
Now there are 12, 001 pages... :lol: :lol: :lol:
Old Jun 13, 2004 | 06:37 PM
REDCROSS's Avatar
Honorary -C-I-C-C-I Member
Default
Wes- what figures did you set up in your GTPro??
As you saw I got some wild figures with mine using 3400lbs. Also I can't get the tach to read the same as the XF tach although the shift lights were spot on!! :roll:
Old Jun 13, 2004 | 07:31 PM
Default
I think you have the G-Tech pro Compitition, from what you have described. Mine is just the G-Tech pro. It just gives HP... 0 - 60 times 1/4 mile times and Longitudinal and lateral Gs. I use 3,400 lbs also and doing HP it avaraged 244. 0 - 60 in something like 5.7 seconds. I haven't done any 1/4 mile times. Because like the 0 - 60 times and HP you need to make several runs in both directions and average them. I just haven't taken the time to find a secluded road where I can make 1/4 mile runs like that. Afetr seeing what I got for HP and 0 - 60 I have some serious doubts about the accuracy of the G-Tech.
Old Jun 13, 2004 | 09:24 PM
drunkiq's Avatar
Default
Originally Posted by REDCROSS
REDCROSS still won't break the tires loose (control off) but you get a bit of a tingle from the "G" force when you lay into it from a dead start and she was pulling good until we ran out of road.
What? do you mean you can't break the tires at launch or that you can't break them in second and third?
Personally I try to prevent the tires from breaking at fast launch and always get a good chirp in second, once in a while in third. I have a buddy that I let drive it last week and he always chirped it in third gear, his shifts where really smooth, fast and always right a redline...
-marc
Old Jun 14, 2004 | 05:37 AM
REDCROSS's Avatar
Default
I am talking about from a dead standing start. I want/try to get ALL the bite to the ground and GO!!!!!!!!!
As to breaking the wheels loose in ANY gear...............Never done it!!!
Might be my old ears but I have never heard a chirp in any gear!!
PLUS at $300.00+ per rear tire for just a bit of showing off is not very cost effective to me. :roll:
Goldwing
21
Apr 2, 2025 11:32 PM
oldvintagedude
Aug 14, 2015 06:20 AM
Valk
Jul 20, 2015 08:17 AM
Bayukbros
Jul 17, 2015 11:21 AM
Seawolf
Jul 12, 2015 06:20 PM
