MIL Codes after washing car?
Old Sep 12, 2012 | 03:30 PM
wraith13's Avatar
Default MIL Codes after washing car?
Ok, If I go thru a carwash or wash the car with a hose I get the MIL and misfire cylinder codes...today I got the 300, 306, 410, 133 codes.....my code reader can never seem to be able to reset the codes and within a few hours or the next dry day no light and no codes.....When I do get the misfire codes the car is actually misfiring....Anyone have a starting point on where to start.....I've only had the car a few months and love it....2004, auto, 52,000 kms....thanks in advance.
Old Sep 12, 2012 | 04:47 PM
Default Re: MIL Codes after washing car?
If there are 0's ahead of those codes (our cars throw FOUR DIGIT codes) then those are an interesting combination, based on the DTC list.
https://www.crossfireforum.org/forum...-dtc-list.html
Old Sep 12, 2012 | 04:57 PM
wraith13's Avatar
Yes, 0's in front....
Old Sep 12, 2012 | 05:34 PM
I take it you do not raise the hood to wash the car. LOL
Old Sep 12, 2012 | 06:06 PM
arejohn's Avatar
O2 sensor, Misfire and air pump..Water getting on Power Train Control module? (it is in a box) It next to the battery under a cover. How does it run in the rain?
Is this a trick question?
Old Sep 12, 2012 | 06:46 PM
wraith13's Avatar
Same issue in the rain...misfire codes, runs like crap til it drys out....ptc module.....hmmmm, i wonder if water is getting in there....when i washed the car i never sprayed any water near the engine compartment...but did around the cowling....box is locked...i'll keep checking.....
Any reason the code reader cannot delete the code???
Old Sep 12, 2012 | 07:44 PM
You should have put that in the first post.
I guess it is obvious something is getting wet. What amazes me is that it clears up after drying out. This tells me it probably is not getting to the circuit board(s), just connectors somewhere. I'd take the cover off the module box next to the battery and have a good look. And signs of water in there?
(That box holds the PowerTrain Control module, Relay Control Module and Body Control Module).
Sounds to me like the PTCM is being compromised in some way - I just cant imagine how water is getting in there even if the cover were off - unless you go to the car wash with the hood up!
Hey........................ here's a clue - the battery ground cable fastens down to a bolt on that wall... I wonder about that connection, water COULD trickle down the side of the wall onto that lug, I guess.
This is an odd one.
Old Sep 12, 2012 | 08:13 PM
How soon after do you try and reset the codes?
Old Sep 13, 2012 | 09:50 AM
wraith13's Avatar
Try to rest the code right away, my reader tries but comes up fail.......
Old Sep 13, 2012 | 10:14 AM
If the fault still exists can it be cleared? The ignition is on and the sensors will still be finding a fault. It may be like trying to re-inflate a tire before the puncture is repaired.
Old Sep 13, 2012 | 04:05 PM
wraith13's Avatar
Ok, the check engine light problem was the engine cover was not snapped down in the back....still have the 4 codes, so that's a start....if i disconnect the battery will these 4 codes reset?...then i can see what else is going on.....Would the cover not being in place cause the misfire codes?
Old Sep 13, 2012 | 04:23 PM
No it would not, get them reset properly and start again.
Old Sep 13, 2012 | 04:34 PM
arejohn's Avatar
Is this the place to go or what!
Old Sep 13, 2012 | 05:28 PM
wraith13's Avatar
Alright, but if the code reader will not reset them and disconnecting the battery will not reset them, what is the proper way to do it????
Old Sep 13, 2012 | 05:31 PM
I've had codes pop up twice, they went away both times with several starts. I was under the impression that ALL codes go away after you fix the problem, THEN, start and drive the car a few times.
As to my Ultragauge, it does clear codes and will turn the light off. Get ya an Ultragauge OR just drive the car.
Old Sep 13, 2012 | 07:55 PM
Page 25-37 of the Manual under "ON-BOARD DIAGNOSTICS" it tells you that a DRBII will erase the codes.
But again, depending on the code, they will go away on their own.
"After three good trips, the MIL is turned off. DTCs are erased following 40 warm-up cycles if the component does not fail again."
But I'm sure you can take it to your dealer and they will clear the codes ... for probably $60 to $150
My local guy does it for free.
Old Sep 14, 2012 | 09:35 AM
wraith13's Avatar
Thanks for the help guys...I'll look into the ultragauge and air pump code next month when i store the car....cheers
mhajek18
Dec 30, 2015 03:40 PM
JEFASOLD
Jul 20, 2015 10:50 PM
srt6-xfire
Jun 29, 2015 09:16 AM
Pacemaker
Jun 18, 2015 10:08 PM
Aaron.Mattison
Jun 17, 2015 03:52 PM
