I can't figure it out
Old May 3, 2014 | 11:53 AM
Default Re: I can't figure it out
Originally Posted by FP
Yes, I agree the draining puzzles me. It only happens when the failure to start occurs, and I let it sit for a while. Once the battery is recharged it starts with no problem. This tells me that something gets reset after the battery discharges.
I am wondering if the relay for the fuel pump has stuck, when you turn the ignition key do you hear the fuel pump stop after a while, say 5 seconds at the most?
I see power going to the relay from a splice which is hot all the time. If the relay was stuck then it would keep drawing power. If not that relay some other relay could be stuck.
Old May 3, 2014 | 12:15 PM
That would not explain the engine not turning over.
Old May 3, 2014 | 12:17 PM
Originally Posted by VALK
He might be the guy to identify your problem quickly
At least you know if ya get a part from Rudy or Rob you are getting the highest quality parts.
He's the one that has been working on my car, but he's not available right now. He's puzzled about the battery draining too. He suggested the next step was to replace the RCM, and since I have a spare I bought, I just finished replacing it. Now it's just a wait and see if the problem goes away.
Cars do not turn over with a flat battery either.
I am looking at two problems and both are because of the RCM.
Put in the 'new' old RCM and see what happens.
Old May 3, 2014 | 12:18 PM
Agree, but I just replaced the battery.
Old May 3, 2014 | 12:27 PM
You missed my point.
You said the battery got drained somehow.
Even new batteries get drained from a continuous bad power leak.
See where I am going?
Old May 3, 2014 | 12:38 PM
I get what you say. But when it first occurs the battery is fine, and the engine starts. But, it dies within 3-4 seconds, and then nothing. No turning of the engine, and all the lights and electronics work, just no clicking from the starter nor engine turning.
Old May 3, 2014 | 12:44 PM
But I thought you said that after that point the battery slowly went flat.
I said can you hear the fuel pump still running when the engine will not start?
Maybe I am just too old and confused.
Good luck with the latest RCM.
Old May 3, 2014 | 02:39 PM
You are old , but I see what you mean......
Old May 18, 2014 | 08:15 AM
Well, it's been two weeks since I replaced the RCM with the spare I bought, and have had no issues. So, I guess I've must have had a bad RCM rebuild. Being proactive bit me in the a-s-s.
Old May 18, 2014 | 10:25 AM
At least your experience helps everyone else. So often people never post their outcomes or solutions to help others. Thank you for sharing.
Old May 18, 2014 | 11:08 AM
OK, so the new RCM cured the problem.
BIG question, what was the problem?
Was it the fuel pump running continuously?
Old May 18, 2014 | 11:18 AM
The problem? A rebuilt RCM that probably has a bad new relay. Not sure which relay was bad.
Old May 18, 2014 | 11:29 AM
Glad to hear that solved your electronics issue.
Now resolve your suspension issues and we will see ya next Saturday
Chicago Downtown Lakefont Cruise - Saturday May 24th
Old May 18, 2014 | 11:32 AM
Oh, the car is very drivable. It's just annoying. See you next weekend....
Old May 21, 2014 | 12:01 AM
Adrian_X's Avatar
If you drive fast enough, you wont have to worry about suspension squeaks hahahah
aerobluehal1
Canada
19
Oct 13, 2018 09:47 AM
Apr 28, 2016 02:04 AM
Ed Mahoney
Other Cars Etc
Sep 21, 2015 10:42 AM
waldig
Sep 17, 2015 10:35 AM
xjken
Sep 6, 2015 11:37 AM
