ESP/BAS Light code C1210
Old Mar 14, 2016 | 06:25 PM
NPB CROSSFIRE's Avatar
Default ESP/BAS Light code C1210
Light has been on for a while Got Creader V111 code reader and first time said" RFnt wheel RPM signal from Trac control system via can bus is implausible." No codes, Installed RFnt wheel sensor, Still light is on, Now its giving code C 1210, ABS OUTLET VALVE COIL RF CIRCUIT FAILURE. I looked up part A0025428918 Q05 Its brake module on Ebay little silver box in pictures. 2 things Does any one think this will fix light problem and also I can"t find where it is in engine compartment. Thanks Aaron
Old Mar 22, 2016 | 12:47 AM
MB04XFIRE's Avatar
Default Re: ESP/BAS Light code C1210
Did you manage to fix your bas ESP light issue?
What type of code reader did you use? What kind of capabilities does it have?
Is your spoiler stuck in the up position as well while having the Bas ESP light on?
Old Mar 28, 2016 | 01:42 PM
kstewart's Avatar
I went to the Chrysler garage to see if they could see what the problem is on my Crossfire. The ESP/BAS light is on so they tried to find out the problem and have no idea what the problem is. They have no way to check it out. They said it might be the computer but not sure. I want to leave Thursday for N.C. I have tried everything I can think of to solve the problem. I guess I got the only Crossfire in the area.
Old Mar 28, 2016 | 01:53 PM
MB04XFIRE's Avatar
That's unfortunate.
You should phone a Chrysler dealer and ask them if they have a drb3 scan tool. If they do they should be able to plug it in and figure out the problem.
Old Mar 28, 2016 | 02:09 PM
kstewart's Avatar
They said they could not find the tool to scan the Crossfire. If they find it they will call me. Last month the battery went dead like something was on. I charge the battery and its fine but never did find what cause the battery to go dead. That could have started the problem with the BAS/ESP light to come on? The car runs great but the brake peddle in mushy. When I start the car I half to drive a couple of miles for the ESP/BAS light to come on. I have check the brake fluid, brakes pads,they are like new, Tire pressure and made sure the correct size tires. Turn the steering wheel all the way left then right then back to center. Will it hurt to drive the car???
Old Mar 28, 2016 | 02:14 PM
MB04XFIRE's Avatar
Did you try the reset?
Start the car and turn the stearing wheel completely to the left. Then completely to the right and then back to the middle.. And that resets the stearing position sensor. And sometimes removes the Bas ESP light.
Old Mar 28, 2016 | 04:59 PM
KDW4Him's Avatar
A mushy feel in the pedal can cause the light to come on. And if you have the original brake fluid you might as well change it.
Old Mar 28, 2016 | 05:51 PM
kstewart's Avatar
T have turn the steering wheel left and right then back to center a doz. times. Down at the Chrysler garage they did that several times also. That the first Crossfire they have in for a long time. They were lost on what to do. They could not find the computer to check the system. Its different from other Chrysler products. I am leaving Thursday for the Tour in North Carolina. Hope the Crossfire holds up?
Old Mar 28, 2016 | 07:50 PM
You ad Dee (The Dragon planning committee) are having the same issues
Her light has stayed off since we aired up the tires and reset it on Saturday so she's off to the Dragon fingers crossed
Old Mar 29, 2016 | 01:21 PM
kstewart's Avatar
Today I went for a test run to see if any change and after driving 5 miles the BAS/ESP light DID NOT come on. I drove 5 miles back home and still the light did not come on. What a surprise but keep your fingers cross. I will be leaving Thursday for North Carolina for the Crossfire tour. That will be a good test.
Old Mar 29, 2016 | 02:30 PM
MB04XFIRE's Avatar
So how did you manage to get you Bas ESP light to go off in the first place?
Old Mar 29, 2016 | 02:55 PM
kstewart's Avatar
Really not sure bur will tell you what I have done. The trouble started when I left the interior light on and the battery went dead. I charge the battery back up full charge then the trouble started BAS/ESP light would come on while driving. But when I turn off the switch then restarted the light would be off until I drive a couple of miles. I got on the internet the Crossfire forum for help. The brake peddle was mushy also. I check the air pressure in all the tires, Check the brake fluid level and toped off with dot 4, I then turn the steering wheel left all the way then right all the way then back to center several times. Still had the problem. I always turn the steering wheel with the BAS/ESP light on. I read the owner's manual several times. Here the last thing I did? The engine was off then I started the engine the BAS/ESP light was off then I turn the steering wheel all the way left, then all the way right then back to center. I went for a short trip to gas up for the trip Thursday and the light never came on. So today I went for a test run 5 miles and the light never came on. Maybe I did not go far enough, I don't know for sure. I will know for sure on the tour in North Carolina. WE drive about 4 to 6 hours the book says. I am trailering the Crossfire down to N.C. I still don't trust the Crossfire as yet.
Old Mar 29, 2016 | 05:15 PM
MB04XFIRE's Avatar
Thanks for the info.
That's great news that the light is staying off.. Hopefully it stays that way..
Best of luck.
Old Mar 29, 2016 | 07:16 PM
kstewart's Avatar
Will find out Friday in N. C. I am using the enclose car trailer to haul the Crossfire down to N.C. If I have trouble I will put the Crossfire in the trailer and drive the truck on tour. Then if someone else has trouble I can help if needed. I have been on several tours Model T Tours, Model A tours, Glidden tours with the AACA about 10 of them all over the USA. Drove a Model T on a 1800 mile tour no trouble. I am always ready to go on tour. Here a few of my Junkers as Dad use to call them
Old Mar 30, 2016 | 10:22 AM
kstewart's Avatar
Today I will load the Crossfire in the trailer for the trip to N.C. They are calling for rain tomorrow is the forecast. I have a 2006 Dodge Diesel truck to pull the car trailer. Really there not enough room in the trunk for our suitcases. When the wife packs she bring enough for a month or two. I do look forward going down to N.C. I was in the Army and with the SF in North Carolina. Fort Bragg was my home back in the 60&61&62. Here a picture of me and a couple of buddies I met in N.C. a couple of years ago. I wanted to cover the Crossfire with this quilt I had made but wife said no. That our Red Crossfire that the wife call it a toy. She think I should get rid of some of my toys. She don't know it that she a toy!
Old May 1, 2016 | 06:21 PM
Well finally got light to turn off. I bought cheap rf wheel sensor on Ebay for $15 MISTAKE since I wasn't sure that was the fix. It caused code reader to throw about 10 codes not related to problem. When pulled it out you could see it was touching hub. So found an original used one and put that in. Light still on ,code reader still had code C1210 but this time said [Fault indictor light on. test drive.] So drove it a couple times no change so decided to check fuses, I pulled numbers 17 and 18 waited couple minutes put them back in and now light is finally off.
Old May 11, 2016 | 04:48 AM
CL770's Avatar
Hi
I had this problem (BAS/ESP light coming on) for a while and regularly re-centred my steering to get rid of it. I put it down to me possibly damaging one of my wheel sensors when I last changed my brake pads and just put up with it. I was talking to a Mercedes mechanic and he said it's a common problem he sees all the time with Mercedes of the same era. It's caused by a faulty brake pedal switch. I fitted a new switch and the problem has never returned. Give it a try!
Old May 17, 2016 | 02:41 PM
sirharper's Avatar
Any update on this? I took a curve hard yesterday and my BAS/ESP light came on. Steering calibration did not fix it. ABS light is not on. Brake lights work fine. No issue with spoiler.
I'm thinking it's a rear wheel sensor since one of them locked for a fraction of a second when I was taking the curve.
Old May 19, 2016 | 10:37 AM
sirharper's Avatar
Edit: Sorry, didn't know "Launch Creeder" was actually the name of the code reader.
Old May 21, 2016 | 05:15 AM
Light is still off, People have asked if Launch Creader V111will work on other things such as air bags, I don't know since never had that problem to test it but it has cleared air bag light on friends F150 also has worked on a couple other cars with wheel sensor problem and been correct. Sorry but I think Crossfires are prone to glitches. Just from disconnecting battery to work on this I had to put over 150 miles on car to get computer to stop saying [ not ready] so I could pass smog test, on most cars it would only be about 100 miles to clear.
sjhamilton2
Dec 1, 2019 07:15 PM
AndrewKeiranMcAllister
Feb 3, 2016 04:12 AM
Greg Fiore
Jan 16, 2016 09:03 PM
dpbayly
Jan 7, 2016 05:57 PM
frankthetank81
Dec 30, 2015 09:43 AM
